Recommended Drag tire for 16x8.5 Z32 wheels
Old Jun 5, 2009 | 09:00 AM
cardana24's Avatar
Blown
I have bought a set of rear z32 tt wheels. They are 16x8.5" with a +35 offset. I want to either mount drag radials or slicks on them, but I am hoping you guys can recomend a size that I can run with out rubbing my suspension and still being able to turn. Is a 255/45/16 the best choice? What do you guys think. Also feel free to recomend an actual tire. My car should be making a little over 300 horsepower. I drag race a time or two every year. I am not a hard core racer but I do try to run PB's every time I go. Opinions?
Old Jun 8, 2009 | 07:09 AM
Nealoc187's Avatar
SLOW
your choices are pretty limited as far as slicks and DRs go, those that I would deem relevant for your needs include:
Hoosier:
17325 P255/50R-16 DOT Drag Radial
17431 26x9.50-16LT Quick Time Pro DOT
There are also a pair of 28" tires you could use, but those are really big for your HP level though they might allow you to avoid a shift near the end of the 1/4, depending on your setup.
Mickey Thompson:
3158M 27.0/10.0-16M (Actually a motorcycle tire but they might be perfect for your needs, I was considering this tire actually because I like the sizing of it but I ended up getting 15" wheels).
3792 26X10.50-16LT ET Street DOT
3793R P255/50R16 26 X 10.50R16 ET Street Radial (drag radial)
M&H
275/55R16 Drag Radial (This would be a 28" diameter tire again)
I think that's about it as far as your selection goes. You might want to make your determination based upon your powerband, you might be able to prevent a shift to 4th gear if you size your tires right depending on your powerband and rev limiter, etc.
Old Jun 8, 2009 | 08:24 AM
cardana24's Avatar
Blown
I don't mind having to shift to fourth. My rev limiter is set at 7000. I enjoy drag racing but I am not a hard core racer.
Do you think most of those tires would fit under the fenders? Some of those seem a bit wide. My car is lowered probably at least 2.5"-3"s
Old Jun 10, 2009 | 08:38 AM
Nealoc187's Avatar
SLOW
the 28" tires might have a problem because of their height, but width wise none of those tires pose a problem. maybe if you crank the wheel all the way one way or the other you might rub, but you don't usually do that while racing.
Old Jun 10, 2009 | 11:24 AM
cardana24's Avatar
Blown
what about these? They seem to be a new tire with not many reviews. But the price is right. The m/t and the Hoosier tires are hard to get below $200. and I had BFG's and would like to try something different.
http://toyotires.com/tire/pattern/proxes-tq
Old Jun 11, 2009 | 01:04 PM
cardana24's Avatar
Blown
Well I could not find many reviews but the price was right and toyo is a reputable account. I have two 255/50/16's coming my way. I will try to remember to post back about them since it does not seem that too many people have run them.
BkGreen97
Apr 2, 2016 05:47 AM
markevans999
Oct 25, 2015 08:27 AM
dcam0326
Sep 8, 2015 11:02 PM
jfl330
Sep 4, 2015 01:44 PM
sdotcarter
Sep 2, 2015 09:53 PM
