Ball-joint/wheel-bearing/tie-rod test via wheel play
Old Aug 25, 2009 | 03:36 PM
ridinwitha35's Avatar
So you're supposed to jack up a wheel and try to push/pull the wheel at 12 & 6 o'clock and at 3 & 9 o'clock. If 12 & 6 show play it might be the ball joint or wheel bearing. If 3 & 9 show play it might be the tie rods. Correct so far?
My question is, how much play is normal and how much is excessive?
Of particular interest is the 3 & 9 test. I can move the wheel about the vertical axis a couple degrees without using much force, however I have new Moog inner & outer tie rods. I'll try to shoot a video soon.
Is there a definitive answer on a) how much force you should apply and b) given that amount of force, how much "play" (if any) is normal?
Old Aug 25, 2009 | 04:47 PM
anomaly117's Avatar
i could be wrong, but i dont think theres supposed to be any play whatsoever. i would check those new tie rods and make sure everything is tight.
Old Aug 25, 2009 | 05:54 PM
Ghost_54's Avatar
^^^ you would be correct, there should be no play at all.
Old Aug 25, 2009 | 06:24 PM
irish44j's Avatar
retired moderator
there should be NO play in the bearing and balljoint.
there could be a little bit of play in the steering even with new tie rods, since they do deflect slightly (they're supposed to), as do the steering rack bushings, especially if they're the originals, which I'm sure they are since Maxima guys rarely if ever change or replace them (and also make sure your steering wheel is locked).
Old Aug 26, 2009 | 07:14 AM
Love_00_Max's Avatar
There should be no play whatsoever!!!
If you are not sure have someone drive parallel and just behind you and have him/her look at the play on the wheels. Under load it is quite easy to confirm play.
Old Sep 13, 2009 | 09:20 PM
So, it seems the play has gotten a lot worse....see these videos. Must be the rack, right?
Video 1: 3/9 test - front view
Video 2: 3/9 test - back view
Old Sep 20, 2009 | 10:48 AM
Yup, I think it is the rack....
Bad rack video
You can see the inner shaft has some play.
Old Sep 21, 2009 | 12:41 PM
Can someone verify for me that the play you see in the video is in fact due to the rack?
Old Sep 21, 2009 | 12:56 PM
vball_max's Avatar
did I hear something about playing with racks?
Old Sep 21, 2009 | 01:15 PM
lol, NO!
Come on, I need to make sure replacing the rack is the right move since it's gonna set me back at least 200 bucks & rent is due next week!
Smackasmith
Feb 1, 2016 12:40 AM
dcam0326
Sep 8, 2015 11:02 PM
jfl330
Sep 4, 2015 01:44 PM
