Did the Willwood brakes fit the SE 16" wheels?
I was reading an article on Overboost.com on wilwood brakes and it got my juices flowin. I remember we hae Wilwood brakes available, but my question is were they able to clear the stock 16" SE wheels on a 4 gen? I did a search and there was no mention.
Re: Did the Willwood brakes fit the SE 16" wheels?
fastbrake@hotmail.com
or
www.fastbrakes.com
i'll test for you guys
I have a set of 17X8" GS400 wheels on with a 50mm offset and they clear with a 6mm spacer. I just got my 17X8" SSR Integrals A2 32mm offset in today. These should definitely clear and then some...although the spoke design on the GS400 are more forgiving. I'll go ahead and test fit the stock 16" SE wheels. I have both a 6mm spacer and 15mm spacer so I'll tell you guys what works.
What would be great is if Fastbrakes would have a template available so people could check to see what wheels would work with the up-size brakes. Then you just print the template, and no guessing.
Great Scott that's a good idea!!!!!!
Lordy = smart :P
Lordy = smart :P
They do fit 16" rims but not sure which ones.
I know Brett aka "Confused" has teh Wildwood kit on his 4th gen. They fit around his 17" Volks and they cleared his 16" rims/drag radials. Talk to him about it. Maybe he can fill y ain some more.
Re: i'll test for you guys
dunno the offset of my 16's. They are MIM (mentos) discontinued and look like they would fit without spacers. I have only tried them with 5mm (my volks use 10mm) and there is plenty of room.
Only way to know is to try.
Re: Re: i'll test for you guys
Originally posted by RussMaxManiac
GS400 wheels are 40mm offset, stock 16s are 45mm.
Re: Re: Re: i'll test for you guys
Gs400 wheels are 50mm. Trust me on that...my wheels are slightly tucked in. The 6mm spacer makes the front to be 44mm and the spoke design does the rest of clearing.
Alright so is the answer to his question, yes? I too am looking to upgrade my brakes in the future but for fear of loosing my stock 16's for the winter i might just get pads and ss lines again w/o the crossdrilled/slotted rotors cause they didn't help me at all on the 95 SE.
Originally posted by clee130
http://forums.maxima.org/showthread.php?threadid=25625
Stock offsets...
I thought that the 97-99 and 2000+ 16x6.5" were 40mm offset and the 200+ 17x7 were 45mm offset. No?
umnitza
Sep 1, 2015 01:03 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
