Engine missing until totally warmed up
Old Sep 8, 2009 | 03:05 PM
williamgd2's Avatar
Help this problem happens with a cold engine.It runs like crap missing on a cylinder for about the first half hour until totally warmed up then it starts working normal.I do have a code scanner and pulled the PO320 code missfire on #4 cylinder but tested all the coils with a muti meter and they all test good.Anyone have an idea of what could cause this??
Old Sep 8, 2009 | 05:02 PM
mtrai760's Avatar
'Trynna' is not a word
The coils can test good and still be bad. Swap the bad cylinders coil to another position. If the misfire changes cylinders, you have a bad coil.
Old Sep 8, 2009 | 05:06 PM
Rochester's Avatar
Good advice.
Happened to me. Probably happens to everyone eventually.
Old Sep 8, 2009 | 05:36 PM
P. Samson's Avatar
I'm assuming you mean P1320.......and you've got the P0304 by the sound of it. The fault detection on this is almost murphy proof with those two codes. I just went through this exact deal, only it was #5 cyl. Just go and buy yourself a left bank coil and change #4, and clear the codes and you're done. And as mentioned, you can test these coils with a mutimeter until the cows come home......they'll appear OK, but it means absolutely nothing.
Old Sep 9, 2009 | 03:39 PM
williamgd2's Avatar
Ok thank you guys I will pick one up
Old Sep 11, 2009 | 06:39 AM
williamgd2's Avatar
I replaced the coil on the #4 cylinder and the car is running better than it ever has,No cel.Thank you again guys for your help.
wingnut2006
Sep 19, 2015 06:13 AM
97_GXE
Sep 15, 2015 06:47 AM
seesole
Sep 14, 2015 12:38 PM
TheMafia
Sep 4, 2015 08:26 AM
A32goldylocks
Sep 2, 2015 06:39 AM
