18x9.5 +30 offset fitment question.....
Old Dec 3, 2009 | 04:31 PM
Keem's Avatar
Hey guys just wondering how much of a fitment problem i will have with rims that are 18x9.5 they also have a +30 offset.... i will be running 225 tires it will have an obvi stretch to it. I will be also be putting in my D2 Coilovers on too.... Im not worried about messing with the fenders.. cuz i will be painting my car too..... But how much effort will be needed to make this work......
Old Dec 4, 2009 | 05:52 AM
phatboislim's Avatar
it should look pretty mean, u will have to roll fenders, but i doubt its gona be extreme
Old Dec 4, 2009 | 06:46 AM
Conrad283's Avatar
I need a truck
9.5's will be pretty tight ... But they should work
Old Dec 4, 2009 | 08:31 AM
perkman87's Avatar
I think its going to scrub.
Old Dec 4, 2009 | 04:02 PM
i smell epicness i wana see pics once installed
Old Dec 4, 2009 | 04:38 PM
Mad-MAX_SE's Avatar
Still kickin'
I was running 19x9.5's +35's front and rear with 235's and only had slight rubbing issues on big bumps, your wheels will only be 5mm out more than mine where. I have D2's as well; if you were to dial in about -2 to -2.5* of front camber you should have no issues rubbing if you roll your fenders flat. With you running 225's you may not have to slightly "pull" the fender on the fronts... That is going to look hella stretched. 235's look too stretched for my taste.
Picture for reference, my sig is the staggered setup:
hope that helps
Old Dec 5, 2009 | 03:34 PM
Leo_Koneval's Avatar
Wow very cool! I love rims with a big lip! But it seems like the tire set up exposes the rim a bit too much, I mean if you accidentally run into a curb it'll instantly hit your rim!
But with great rims come great responsibility...
Old Dec 6, 2009 | 09:09 AM
Keem's Avatar
My buddy is running 18x9.5 with 215's!!!! i like the look if a stretched.... but im not doing 215! but i think 225 will look a nice.....
Old Dec 12, 2009 | 07:27 PM
e-subliminal-2's Avatar
hope that helps
I want ur rims
Old Dec 13, 2009 | 08:06 PM
tigersharkdude's Avatar
^^I want your rims
Old Dec 14, 2009 | 04:14 PM
mouasksry's Avatar
Thanks you have information:
1. 2000 pearl white 5 spd all basic bolt ons g35 whls, it was good while it lasted.
2 87 stang Project 306ci built motor full susp. (in garage) its sloow .
Old Dec 14, 2009 | 04:30 PM
perkman87's Avatar
Why ???????? thats my lineup
perkman87's Avatar
and Im in for pics
Its gonna look Kink as hell
Old Dec 15, 2009 | 06:05 PM
whiteSE's Avatar
its spam. its appearing more and more
Old Dec 15, 2009 | 06:55 PM
Crusher103's Avatar
i was rubbing with stock Z wheels which are 18x8.5 on a 30mm offset. so start planning on some fender work.
Old Jan 4, 2010 | 09:36 AM
doublea's Avatar
I think it's not a good idea to run 225 on a 9.5" wheel, the tire will be stretch to a point where you run on the side wall > not good at all for safety. If you want to run a 225 tire size then any of the 7" - 7.5" - 8" wide is perfect. On a 9.5" wheel the minimum, I would recommend is at least 245 otherwise your are compromising your safety.
Old Jan 4, 2010 | 02:06 PM
beefy23b/97's Avatar
^^^ agreed ^^^^
I always thought the only reason for a wider wheel is to accommodate a wider tire. My buddies 99 LS1 camaro has 9.5" wheels and he's running a 275 (stock). Save your money, If your only running a 225 buy 7.5" wheels.
Old Jan 7, 2010 | 03:35 PM
XeroX's Avatar
Hella internets
I have seen stretch WAY worse than what OP is trying to do, and i havent really heard of any blow outs or anything...More like bent rims and what have you...
Originally Posted by beefy23b/97
^^^ agreed ^^^^
Its the look. sitting flush with stretch pokin barrel out of your fender is gangstarrr just not very practical...
Its just a style with imported cars basically...
Old Jan 18, 2010 | 05:41 AM
D0NK3YCH0NG's Avatar
nice
Old Jul 12, 2018 | 10:12 PM
NPaulic's Avatar
Do you know if stock 350z wheels 18 by 8 +30 offset on 45 series 245 tires would fit on an 03 maxima with no rub?
euromaxima
Oct 9, 2007 06:57 AM
FriscoMaxima
Tires and Wheels
May 31, 2006 09:13 AM
thephatOne
Tires and Wheels
Feb 12, 2005 11:46 PM
timmy g
Tires and Wheels
Oct 9, 2004 02:42 PM
wicked_ryder
Mar 5, 2004 12:28 PM
