97 maxima wont start in cold weather?
Battery, Starter, Cam Sensor, Ignition Switch. Thought it was due to Battery so once I had that replaced still had a Cold Start up issue, then i replaced the Starter that lasted for awhile but then problem came back, then once i replaced both the Cam Sensor and Ignition Switch, starts up even in 20degree weather
I had 3 different types of starting problems with my old 96 maxima.
(starter, air flow meter, engine fuse)
now I got a 98 max that I bought in april. so the weather was warm in LA up until now.
in the mornings its about 50 degrees and when I start the car the rpm would drop way too low and bounce back. but today it didnt come back up and the engine turned off.
today I wanted to order a new fuel filter but I thought I should ask u guys if anyone knows where i should start checking first.
more info about the car:
battery has a sticker 5/05 and I put in a system 2 months ago.
short ram intake. (either messed up the throttle body or the air flow meter?)
try the crank position sensor, on the botton next to the oil filter and the harness my 97 max did not start in cold weather changed the sensor.i found out the wire harness was not getting any ground.i used a digital multimeter test the conections ....
I imagine most regular members here may not like your lights but I find them very nice. Really cool look. Not sure about the fogs but..they're not awful. Awesome headlights though and i like the turn signal lights.
Lakersallday24
Nov 7, 2024 07:31 PM
kirkhilles
Aug 8, 2015 10:53 AM
dmv are big time crooks!!!!!!!!
