Seized caliber?
Old Jan 20, 2010 | 04:30 PM
Kevin319's Avatar
Seized caliber?
I was changing my oil the other day and noticed one of my wheels does not spin freely like the other. The rear passenger wheel seems like it is jammed and doesn't want to rotate unless you force it. There is no "thumping" noise when I am braking or driving ... but I did have new rotors and brake pads put in that screeches when braking. Any comments?
Old Jan 20, 2010 | 04:48 PM
POSER30's Avatar
check emergency
Old Jan 20, 2010 | 04:56 PM
zero2sixtyZ's Avatar
You embarrass me.
OEM calipers are notorious for seizing. Did you install the brakes yourself?
Old Jan 20, 2010 | 05:11 PM
Kevin319's Avatar
No my dad's mechanic installed new rotors and brakes (cause I had original rotors that warped) when he brought my car in for inspection. I called the mechanic back and he said that the wheel hub didn't spin freely when he took the caliper and rotors out. He thinks its the boot?
Old Jan 20, 2010 | 05:28 PM
foodmanry's Avatar
Da Roller Coaster!
Good mechanic seeing an issue and not doing anything.
Only way to tell is take the wheel off on that side and inspect. Without the wheel you should still be able to spin the rotor if car is out of gear of course...
It is either a siezed caliper or the rear guard behind the rotor is rubbing against the rotor.
When was the last time the brake fluid was flushed? It should be done every two years. Moisture can build up in the brake fluid which can cause seizing of the calipers.
Old Jan 20, 2010 | 05:47 PM
Kevin319's Avatar
The wheel was taken out along with the calipers and rotors. He visually checked to see if anything was rubbing but he claimed its the boot and it needs to be replaced. I asked my dad and he did tell him but he forgot to relay the message to me.
I have had the car for 2 years now but the brake fluids haven't been flushed. I'll look into that with the mechanic as well ...
Old Jan 20, 2010 | 07:41 PM
b15philly's Avatar
Same thing happened to me when I had mine done. My passenger side rear caliber was sized and need to be replaced, luckily I was able to get one off of a junk yard car because new they are pretty expensive.
Old Jan 20, 2010 | 09:27 PM
foodmanry's Avatar
Da Roller Coaster!
The boot for your CV joint is not related to the dragging of the wheel. Honestly, not doubting your mechanic, but pull the wheel and double-check it yourself. It wouldn't hurt and maybe you will see something the mechanic did not catch.
Old Jan 20, 2010 | 09:34 PM
Kevin319's Avatar
How much was it off the junkyard?
I will definitely jack the car up and check it out this weekend. Would I need to put the car into neutral or park? My backyard does have a little decline ... don't want the car rolling into anything now ...
Old Jan 21, 2010 | 06:20 AM
b15philly's Avatar
I think I got it for like $35 or $40 some ware around that price. New I thing its around 350 from the dealer
Old Jan 21, 2010 | 04:22 PM
foodmanry's Avatar
Da Roller Coaster!
Needs to be in neutral. Make sure the parking brake (e-brake) is on when you jack up the front. If you are really worried about it, put blocks behind your rear wheels.
02MaXiMa_GLE
Sep 12, 2023 11:29 AM
BkGreen97
Apr 2, 2016 05:47 AM
humberto_i30
Feb 28, 2003 07:32 PM
