Power Steering Belt won't Tighten???
Old Feb 3, 2010 | 06:01 PM
haydeno's Avatar
Belt broke snapped again on way home. About two months ago my PS belt tension bolt broken and I replaced it. Now I cannot get it to tighten! After I got crank pulley to move back over so i could put on the new PS belt, I try to tighten the belt back up, the bolt moves but belt doesnt tighten nor is the bolt on tension. Anyone had similar problem?
Old Feb 3, 2010 | 06:14 PM
ImmaSquashYou's Avatar
did you loosen the other bolt that is on the back of the power steering pump?
1st pic
http://www.greghome.com/images/Maxim...DriveBelts.jpg
Old Feb 3, 2010 | 06:55 PM
dgeesaman's Avatar
Maintenance Monster
Two things:
1) Yes there is a pivot bolt that is accessed on the back side of the psp. This must be loose for the adjust bolt to do anything. It's on pretty tight and I need an extended pivoting ratchet to work on mine, and it barely fits.
2) The PS adjust bolt is left-hand threaded. Tighten it the opposite way as the other tensioner.
3) Do not overtorque on the adjust bolt. The bracket will break and that's even harder to replace than working on the psp correctly.
Old Feb 3, 2010 | 10:55 PM
Maxima_Joe's Avatar
4th Gen Parts King
Your bolt is on wrong. Between the head of the bolt and before the threads start is where it should be positioned on the bracket.
Old Feb 3, 2010 | 11:52 PM
smai555's Avatar
+1^ i was just looking at that and seems like the space above the head should in that bracket
Old Dec 24, 2012 | 08:33 AM
swolemax's Avatar
i was replacing my power steering belt and the tension bolt came off im having difficulty puting it back on what ami doing wrong i need help asap
Old Dec 29, 2012 | 07:03 PM
pootsie's Avatar
I think I have this problem. The tensioner bolt doesn't tighten the belt
It looks like the flange is below the bracket. How do I get it back on correctly?
lowpost99
Oct 26, 2025 06:53 PM
markevans999
Oct 25, 2015 08:27 AM
2kmaximel
Sep 10, 2015 08:13 AM
ag90fox
Sep 9, 2015 12:22 PM
SusieQQ
Sep 9, 2015 12:14 PM
