00 SE 50k miles, strange noises?
Old Mar 9, 2010 | 07:04 AM
Domf3's Avatar
I have an 01 AE and a friend just purchased an 00 SE. Both are auto. I noticed his does something mine doesn't.
Pressing the throttle in park (not sure if it happens in gear), results in a strange mechanical sound. Sounds like its comming from the engine bay. It's high pitched, like a servo opening/closing. It happens for a second as you press the gas, rpms go up (it stops) then the noise comes back when the idle returns to normal for another second and stops?
The car also had a rough idle on cold start but once warm its fine. Ideas?
Old Mar 9, 2010 | 07:13 AM
Feldman's Avatar
motor mounts?
search electric motor mounts and you will find some treads on them
Thats my guess though without a video or a sound clip
The rough idle on startup is most likely intake manifold gasket. There were 2 threads on that last week both titles were something like "car studders when cold"
Old Mar 9, 2010 | 07:58 AM
Domf3's Avatar
Most of my searches turned up MAF issues but that seemed odd being a low mileage 00 with paper air filter. The noise is hard to describe, I'll do some searching and if that doesn't help I'll post a clip.
Old Mar 9, 2010 | 08:45 AM
maximal01's Avatar
i have the same issues but i have only noticed poor mpg in the cold and only 22 when its warmer, but when i run seafoam through it i get some smoke coming out close the firewall have you tried this?
Old Mar 9, 2010 | 10:52 AM
Domf3's Avatar
I have not tried the seafoam. After much reading I'm going to start by troubleshooting the motor mounts (unplugging them). I doubt that will fix the idle but it may save the ecu. When should these motor mounts be unplugged (off, running at idle, while revved, etc?) I couldn't find that info, many suggested unplugging them while the car was being revved to keep the mounts in 'hard' mode? And unplugging them at idle would make the ecu keep them in 'soft' mode. This is very interesting and also a PITA lol.
The intake leak sounds responsible for the stumbling idle. Somebody suggested holding a lit cigarette around the intake to check for leaks? Is this safe?
Old Mar 9, 2010 | 09:38 PM
grip1968's Avatar
Do SEAFOAM really work, I seen a couple of you tube article of this stuff, I was wondering if I should try it in my 2000 Max 176,000 miles
Old Mar 10, 2010 | 12:15 AM
maximal01's Avatar
it wont hurt the engine as far as smoke getting sucked in its not like itll be taking up the habit
Old Mar 10, 2010 | 01:12 AM
BronxSleeperMax187's Avatar
yes it works,just put 1/3 of a can threw booster hose very slowly and rest in gas tank with atleast A half A tank of gas......I used A spray bottle for booster hose leading to intake manifold and kept spraying every 10 seconds.....get ready for alot of white smoke after you start driving,and don't gun it....drive slow around the block till smoking stops.....your neighbors will love you too when they see the smoke
Old Mar 11, 2010 | 06:05 AM
Domf3's Avatar
I noticed the motor mount noise (robot/servo/whirring) only happens when the rpms are at 900 on the way up then again as the tach needle passes 900 on the way down. The videos I listened to had a similar sound but it was happening at different times ie: turning the car on/off. I still need to unplug, I'll update this weekend.
Old Mar 11, 2010 | 09:39 AM
mandyfig's Avatar
Sure the whining is not coming from the belt?
Old Mar 13, 2010 | 10:28 AM
Domf3's Avatar
It's not a belt issue. I'm still waiting for this rain to subside so I can troubleshoot further.
Old Mar 16, 2010 | 04:47 PM
Domf3's Avatar
I believe Feldman was correct on both issues. I unplugged the front motor mount and the noise is gone. I was unable to find the leak in the manifold but it makes sense. Now that the weather is in the 60's the stutter is gone.
The car still has a 30 day warranty. Wish me luck with the dealer.
Old Mar 17, 2010 | 06:19 AM
DavidP's Avatar
I had same noise in my 2000 SE and it was the weird electric motor mounts I had them replaced and its gone now
Old May 6, 2010 | 06:19 AM
Domf3's Avatar
An update for anybody searching. THe idle problem went away after replacing an 02 sensor. The 'noise' was in fact the motor mount.
alahjahwan09
18
Sep 21, 2015 09:12 PM
thenewguyy
Sep 12, 2015 11:12 AM
ballerchris510
Sep 11, 2015 05:29 PM
crazyespn
Sep 3, 2015 01:30 PM
