2K2 Tails: Bulbs
Old Dec 9, 2001 | 02:03 PM
MichaelAE's Avatar
2K2 Tails: Bulbs
Are the bulbs on the 2K2 tails different than the 2K1's? Am I just crazy or what. The 2K2's have big-a$$ wedge bulbs in the parking light and brake light. Argh!!! They are not 1157 and 1156 bulbs.
Old Dec 10, 2001 | 09:39 AM
MichaelAE's Avatar
bump
Really? Nobody on this one? I don't have a manual, so I can't look up the bulb type...they are not the 194 base with a large bulb...they have a larger base...anybody?
Old Dec 10, 2001 | 11:11 AM
flerve's Avatar
im having the same problem as you. i bought just the shells for the 2k2 tails and now my turn signal bulb wont fit into the hole for the new tails. i need to find out if i can find a smaller bulb that will fit in both the 2k wiring harness and in the hole for th bulb in the 2k2 tails.
Old Dec 10, 2001 | 11:27 AM
MichaelAE's Avatar
7440 and 7443 maybe?
You checked the hole size too. I didn't even do that. I happen to think, oh yeah, I can just switch the harnesses, but if the hole is too small for the 1157 and 1157, that wouldn't work.
FYI...the reverse bulb fits both the '00-'01 and the '02. Just the parking light and brake light that is a problem.
Old Dec 10, 2001 | 03:56 PM
punkdork's Avatar
The break is a 3157 I believe. Can anyone confirm that?
Old Dec 11, 2001 | 04:22 PM
flerve's Avatar
the break light fits fine, its just the amber turn signal bulb that doesnt fit any more. if the break is a 3157 would it fit into the old wiring harness still?
there has to be someone who has went through this before...
Old Dec 11, 2001 | 04:31 PM
MichaelAE's Avatar
The brake light was a 1157 on the 2K1 tails. The bulb may clear the hole, but the harness won't work.
Old Dec 12, 2001 | 12:30 AM
flerve's Avatar
i am currently driving around with my 2k1 harness and 2k2 tails and i can tell you the break light works just fine. i just put the blinker light outside of its actual compartment so that you can still see the blinker light, its just rather dim. the break light and the reverse lights work perfect, but i need a better solution for the blinker light.
Old Dec 12, 2001 | 07:25 AM
DAVEB's Avatar
I've got the harnesses in stock to fix this problem. Haven't researched the bulbs yey, but I'm sure I can figure something out!
-David Burnette, Town North Nissan
TallTom
57
Oct 14, 2025 05:16 PM
doctorpullit
Mar 29, 2016 11:08 AM
mpbclutch33
Dec 26, 2015 11:11 AM
knight_yyz
Nov 1, 2015 01:34 PM
Noela
Sep 26, 2015 08:22 AM
