Chirping sound coming from engine ...
Hey guys,
I have noticed a chirping sound coming form the right-side of the engine (closest to the air intake). It only happens first thing in the morning or at idle.
TIA,
G
TIA,
G
it's definitively rotational based. It's a high-pitch squeak that sounds more like a chirp... I'll check again, but I'm pretty sure is coming from the battery side.
I had a sound similar to this . In the morning or when it was raining it was annoying. Turned out My main bolt was missing on my alternator... And let me say it's a pita to get to.
Sorry just my .02
Sorry just my .02
The chirping/squeaking noise is coming from the clutch. It goes away when press the clutch pedal. I can hear it whenever it's on neutral and I'm not pressing the clutch pedal.
Any advice? Is the clutch going bad?
When does the noise occur? Does it happen when the clutch is pressed in or when the trans. is in neutral? Bah, nm. For some reason I completely missed your last post.
As I said before though this sounds like it could be a bad throwout bearing.
As previous posters have noted, I've found some information that also points to a throwout bearing. Another one suggested pumping some grease through a grease nipple on the bell housing of my truck, which I haven't tried yet.
I get that too at very low RPM, got it checked out, guy said when the belts are changed it should go away. Also it happens more often after rainy weather. Dont think it should be much of a problem it its just a sound and no difference in car's behavior.
The noise is more noticeable when it's colder out and like I said before it's not coming from the acc. belt area. It's coming from the tranny housing.
As previously mentioned, it's most likely your TO bearing. Classic symptoms.
OT - Why are people continuing to post about the belts and pulleys when OP stated it was from the driver side AND later stated it was correlated to clutch pedal movement?
MaximaDrvr
Aug 19, 2015 08:20 PM
Jcof88
Aug 3, 2015 10:43 PM
