Chirping sound coming from engine ...
Old 10-16-2010, 06:07 PM
gdal's Avatar
Hey guys,
I have noticed a chirping sound coming form the right-side of the engine (closest to the air intake). It only happens first thing in the morning or at idle.
TIA,
G
gdal is offline
Old 10-17-2010, 12:20 PM
CraigSE's Avatar
Is it rotational based or is it constant?
I was going to suggest pulley bearing, but not if its on the battery side of the engine..
CraigSE is offline
Old 10-17-2010, 04:26 PM
gdal's Avatar
it's definitively rotational based. It's a high-pitch squeak that sounds more like a chirp... I'll check again, but I'm pretty sure is coming from the battery side.
gdal is offline
Old 10-17-2010, 04:31 PM
michael454rs's Avatar
i have a chirp also but mine is coming from one of the pulleys dont witch one lol
michael454rs is offline
Old 10-17-2010, 05:21 PM
Mr. Brett's Avatar
Well, take a stethescope and poke it down in there. It'll tell you which pulley is squealing real fast.
It might also be an over-tightened/loosened, or worn belt.
Mr. Brett is offline
Old 10-17-2010, 09:35 PM
datsunzcar84's Avatar
I had a sound similar to this . In the morning or when it was raining it was annoying. Turned out My main bolt was missing on my alternator... And let me say it's a pita to get to.
Sorry just my .02
datsunzcar84 is offline
Old 11-03-2010, 11:37 AM
gdal's Avatar
The chirping/squeaking noise is coming from the clutch. It goes away when press the clutch pedal. I can hear it whenever it's on neutral and I'm not pressing the clutch pedal.
Any advice? Is the clutch going bad?
gdal is offline
Old 11-03-2010, 11:44 AM
kbohip's Avatar
Sounds like it's the throwout bearing. My parents used to have a '90 Pathfinder which made the same noise. They never got it fixed and so far it's still going. I think it's only had around 20-30k miles put on it since the noise first started though. Actually, it could also be a pilot bearing.
When does the noise occur? Does it happen when the clutch is pressed in or when the trans. is in neutral? Bah, nm. For some reason I completely missed your last post. As I said before though this sounds like it could be a bad throwout bearing.
kbohip is offline
Old 11-03-2010, 12:48 PM
mandyfig's Avatar
Surre it is not the alt?
mandyfig is offline
Old 11-03-2010, 01:28 PM
Nelsito65's Avatar
I have a Chevy pick up truck with the same issue. The chirping goes away as soon as I tap on the clutch. I noticed that the clutch pedal sits much higher than the brake pedal and I have thought about jamming something at the base of that pedal so it sits at a level closer to that of the brake, but I'm not sure if that would cause damage to the clutch.
As previous posters have noted, I've found some information that also points to a throwout bearing. Another one suggested pumping some grease through a grease nipple on the bell housing of my truck, which I haven't tried yet.
Nelsito65 is offline
Old 11-11-2010, 06:09 PM
gdal's Avatar
I did some more research here and it seems that the input shaft bearing is going out ... pretty penny ... ouch
gdal is offline
Old 11-12-2010, 05:25 PM
gdal's Avatar
I need to get it checked ... it just sounds like a squeaky belt and it doesn't happen all the time. The clutch seems fine and its quiet.
Any advice fellas?
gdal is offline
Old 11-12-2010, 05:29 PM
coldfear13's Avatar
I get that too at very low RPM, got it checked out, guy said when the belts are changed it should go away. Also it happens more often after rainy weather. Dont think it should be much of a problem it its just a sound and no difference in car's behavior.
coldfear13 is offline
Old 11-12-2010, 05:38 PM
gdal's Avatar
I had my belts and tensioner replaced and the noise is still there. It's just annoying ... I'm concerned because I hope is not the input shaft bearing, but I'm not having any issues/weird noises coming from the clutch.
The noise is more noticeable when it's colder out and like I said before it's not coming from the acc. belt area. It's coming from the tranny housing.
gdal is offline
Old 11-12-2010, 10:48 PM
"I'm just sayin'..."
nelledge's Avatar
As previously mentioned, it's most likely your TO bearing. Classic symptoms.
OT - Why are people continuing to post about the belts and pulleys when OP stated it was from the driver side AND later stated it was correlated to clutch pedal movement?
nelledge is offline
Old 11-13-2010, 10:20 AM
detailerdaveb@gmail.com
maximadave's Avatar
my Max is doing the same. It is the throw out bearing Mine has been making noise for the last 3+ years.
maximadave is offline
MaximaDrvr
08-19-2015 08:20 PM
Balkins
08-12-2015 06:39 AM
follyburr
08-07-2015 09:50 PM
Jcof88
08-03-2015 10:43 PM
Quick Reply: Chirping sound coming from engine ...
