New Personal best...Wish it was better.
These times were on my new Nitto NT555R drag radials with 16X8 RX7 wheels.
Only 2 passes today. The track was very busy. I burned out the same. I would go to the edge of the water box and burn out in first gear for about 4 or 5 seconds. I tried two different tire pressure amounts.
1st pass at 20 PSI 2nd pass at 15 psi
60 Ft - 2.234 60 Ft - 2.196
330 - 6.16 330 - 6.178
1/8 - 9.34 1/8 - 9.42
1/8 MPH - 78.38 1/8 MPH - 76.7
1/4 - 14.44 1/4 - 14.63
MPH - 96.59 MPH - 94.29
What I don't get was that my second pass had a better 60 ft, but everything else was slower. Maybe I should try to learn how to get a perfect launch at 20 psi tire pressure.
I need practice! I was hoping for 13's. I'm going to try and go back in November before our track closes down for the winter.
It is gonna be hard to run 13s with that mph. It's possible, but you will need a great 60ft.
Temps: 60. DA: 1158. Cut out open. The funny thing is that the da calculator said I could have run a 14.2 The last time I ran it was in 90 degree summer heat on street tires, and the da calculator said I could have run a 14.1...Go figure. I think I need practice finding the sweet spot with the drag radials. Maybe I'll get NWP Spacers to round out my bolt ons.
Good luck next time man!
2 passes isn't enough to make a determination on what tire pressure you should be running. make some more passes and keep notes and you'll start to get a clearer picture of what you should run your tires at.
I need to adjust my e-brake. It wouldn't hold very well when I tried to burn out. The car would start pulling forward almost immediately. Also, with an auto, is it best to hold the brake down and rev it up a bit before launch or should I leave off idle speed? I was holding the revs up a bit, which is what I did on street tires.
One of the best mods you can make is seat time.
Srry I misread where he had radials.... tires aren't really that beneficial to auto's as you can pul 2.0's on street tires and really can't launch much higher than 2.2K... do a bit more justice with an upgraded TC
If you don't know how to do the swap yourself it will get really expensive.
Check out edge converters, that's what Aaron and Jime run.
That's very reasonable. If I add more mods that will be the one. If I can some how get to the 13's with my current set up, then maybe I won't do it. I have to decide if I will be happy with 13's or if I will just continue until I get to 12's...We'll see. Anybody remember what a higher stall converter took off your et?
read post #1296
http://forums.maxima.org/all-motor/5...thread-33.html
there will be a new stall converter if everything goes as planned.. it'd be worth the wait if you go that route
read post #1296
TallTom
57
Oct 14, 2025 05:16 PM
Mar 12, 2020 12:06 AM
pears
Sep 18, 2015 05:25 AM
