Can't get axle out...
Old Oct 22, 2011 | 12:09 PM
DBear's Avatar
I'm replacing my front right (passenger) axle. I got the knuckle off easily enough, but I just...can't...get...the axle to come out. I've tried prying with my Mother of All Screwdrivers, but there really isn't a lot of good leverage down there. I'm prying against the small lip inboard of the inner boot, so it's a deccent pry point. I've got some room to whack on the handle of the screwdriver with a rubber mallet, but it doesn't help. I've tried yanking on the axle itself (between the boots) too. There's about an inch of give, and then it feels like I'l pulling on the whole axle, but that isn't doing the job.
I've already spent an hour on this part alone. Anyone have any suggestions on how to get this thing out??
Old Oct 22, 2011 | 12:12 PM
ATTappman's Avatar
Did you remove the three bolts on the carrier bearing bracket?
Old Oct 22, 2011 | 12:29 PM
DBear's Avatar
No, since I don't even know what that is.
Old Oct 22, 2011 | 12:30 PM
DBear's Avatar
BTW, it's an AT.
Old Oct 22, 2011 | 12:35 PM
DBear's Avatar
Well f*** me for being an idiot. I see it now. I thought that was part of the axle assembly, but I see where it comes off. I'll try that. Thanks.
Old Oct 22, 2011 | 02:01 PM
315max's Avatar
take the three bolts off that connects the carrier to the axle. if you still ant get it out take out the three bolts that hold the carrier to the car. its a b**** to get them apart due to corrosion and old age
Old Oct 22, 2011 | 02:29 PM
JNCoRacer's Avatar
Just the tip.
Thats why I always put grease on the mating surface where the carries bearing slides through.
Old Oct 22, 2011 | 02:50 PM
DBear's Avatar
I can't even get in there to get any leverage on the bolts. It shames me to say it, but I think I'm going to have to punt on this one.
Old Oct 22, 2011 | 03:38 PM
315max's Avatar
you can do it. its a pain the first time, i kno from experience. just keep working on it
Old Oct 22, 2011 | 05:05 PM
Br0nz's Avatar
yup just finished this repair, i had to use an air chisle no way i couldve gotten it otherwise!
Old Oct 22, 2011 | 09:36 PM
Snypa's Avatar
Air chizzle did it for me too...so much that I only have 2 bolt holes instead of 3. Glad you got it though. !
Old Oct 22, 2011 | 11:27 PM
Br0nz's Avatar
yeah it was all going smooth like 20 min in i had all three bolts out of the carrier bearing but hrs later i still couldnt budge the axle. so i finally called my bro to bring me a bigger compressor and the ingrosol rand air chisel!
op if you have airtools i strongly suggest investing in a good air chisel
air chisel > *
Old Oct 22, 2011 | 11:39 PM
Snypa's Avatar
air chisel > *
I think doing it by hand would work too, big chisel + Big hammer + hammering Muscles.
Old Oct 23, 2011 | 04:43 AM
Br0nz's Avatar
theres no room to get a good swing i tried that, i mean im sure i CAN be done but.. i had access to a tool that hits at like 30/sec!!
boomerbrian
Oct 31, 2018 10:25 AM
RealityCheck
Oct 2, 2015 06:34 PM
The Wizard
24
Oct 1, 2015 08:47 PM
followthadollar
Sep 17, 2015 06:31 PM
FanaticMadMax
Sep 4, 2015 02:45 PM
