hit a curb need help
Old Feb 14, 2012 | 12:28 PM
max_overdrive's Avatar
i hit a curb in the snowstorm we had yesterday at about 10mph now the wheel is kicked in at the bottom and toe out some. i replaced the ball joint but that wasn't it, i would like some feedback on what i could be. i think the lower control arm is bent down near the steering stop.
sorry the pics are so big.
Old Feb 15, 2012 | 02:08 PM
arsonist63086's Avatar
is the other side ok? .... does the rack n pinion turn ok with out noise? if it does its damaged and needs replacement.. if everything seems fine then u ill have to just adjust your toe but unscrewing out the ball joint till its right straight again... but mu guess your rack n pinion its messed up...
Old Feb 15, 2012 | 06:39 PM
T_Behr904's Avatar
It's difficult to tell in the pics, but something might be bent or knocked out of place.
Old Feb 15, 2012 | 08:36 PM
LvR's Avatar
LvR
Sorry, but what am I missing here?
You know for a fact that you yourself cannot set wheel alignment properly - not by eye anyway and even with replacing every steering and suspension component ..................... so why are you replacing anything at all? - take the thing to an alignment facility and have them adjust it properly - if they cannot they will tell you what needs to be replaced.
What anybody may be suggesting here is a crap-shoot and waste of money
Old Feb 16, 2012 | 08:40 AM
the other side is fine , and besides pulling it turns fine with no noise.
the only reason i replaced the ball joint is it looked like the paint had been chipped off,like it bent. im waiting to get payed to get a alignment.
Old Feb 16, 2012 | 09:37 AM
ShocknAwe's Avatar
yes take it to an allignment shop and have them allign a wheel that is obviously out of position. Let them tell you the whole suspension needs replacing while your at it. huh? Now to give a sensible answer there is obviously something bent or out of position. I would jack it up and have a friend turn the wheel so I could see if anything looks broken or bent.
Old Feb 16, 2012 | 10:53 AM
LvR's Avatar
LvR
................ Now to give a sensible answer there is obviously something bent or out of position. I would jack it up and have a friend turn the wheel so I could see if anything looks broken or bent.
What an absolute novel approach ................. oh yes, and I guess once you are done just like the OP currently is by his own admission, you only then take it to the shop?
Old Feb 16, 2012 | 06:32 PM
i played around with it today after changing 2 bad injectors (its nice to have this thing running at 100% finally) and the top camber bolt was way out of adjustment so i moved to back but my toe is still out. i tried to adjust the tierod end but it was seized so i will let the shop deal with it. but its at least drivable now.
Old Feb 16, 2012 | 08:55 PM
maximo018's Avatar
Well I had something happen to me similar to the OP but my car spun out & hopped a curve. Needless to say hands were at 2 & 8 to go down the street straight.
Old Feb 17, 2012 | 11:28 AM
CMax03's Avatar
This is a real easy one! If you can't visually see what is damaged take it in for an alignment......
Old Feb 17, 2012 | 01:01 PM
i took it in today and $60 later all is normal. thanks for the help.
Old Feb 18, 2012 | 12:57 PM
jordan101's Avatar
alignment all the way
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
D Mason
Jun 21, 2016 04:43 AM
Dennis Twohy
Oct 1, 2015 06:01 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
