grinding noise while turning
Old Mar 6, 2012 | 06:13 PM
michael454rs's Avatar
hey guys need a little help, my maxima is making a grindings noise while turning to the left, wanted to know what are some things to look for? wheel bearing, cv axle. ball joint? thanks
Old Mar 6, 2012 | 06:46 PM
DennisMik's Avatar
I would check the CV axle first then the wheel bearing. The ball joint would not cause the noise.
Old Mar 6, 2012 | 07:03 PM
what are sings to look for a bad cv axle, i cheked for torn a boot but there there also it doesnt make the clack clack clack sound its more like a grinding? can the cv axle still cause that noise?
Old Mar 6, 2012 | 09:19 PM
DennisMik's Avatar
A torn boot can sometimes be hard to see, depends on where the tear is. In my limited experience with cv axles, they have made a higher pitched pinging sound, not what I would describe as a clack. Do you know which side of the car the noise is coming from?
Old Mar 6, 2012 | 09:43 PM
KT3MaxSE's Avatar
Is the 'grinding' coming from the the front or rear? IF it's from the rear and you turn left and the sound's from the right rear then I'd have to say right rear hub bearing/assembly, if it does it on right turns, then left rear hub etc.
Old Mar 6, 2012 | 09:54 PM
It coming from the front left, you guys think is the wheel bearing?
Old Mar 6, 2012 | 10:20 PM
KT3MaxSE's Avatar
I think it could or might be the wheel bearing BUT personally I can't/won't say definitively as I could IF we were talking rear hub bearing noise when turning. I haven't had issue w/ my front hubs (only the rear) so that's what I have for you.
Old Mar 6, 2012 | 10:40 PM
It most def somethin in the front because it can felt thru the steering wheel, tought.it was my steering pump but not making any noise, no leaks fluis is good. Either axle or wheel bearing.
Old Mar 6, 2012 | 11:18 PM
2brosgixxer's Avatar
Check your wheel bearings on the front. Very simple to do...jack up the car, place hands at 12 and 6, wiggle the tire back and forth and see if there is any play. Not sure what the specs are as to if there should be a slight amount of play or not. Post back your findings on the check and I'm sure someone can help once we know if you have any play in the bearing.
Check CV's by turning steering wheel to extreme right, put car in reverse and do slow circles in an open empty parking lot...if you hear clicking, you have a bad CV. Then turn wheel to extreme left, put car in reverse and do slow circles...if you hear clicking, you have a bad CV. Depending on which direction you are turning when hearing the clicking, it could be either the right CV of left CV. Do these checks and post back. Hope this helps a little.
Old Mar 9, 2012 | 10:41 AM
Tyler79's Avatar
Funny thing my 01 maxima has the same issue on the front drivers side and only when i turn the wheel all the way to the left i hear a grinding sound. I just noticed this a week or so ago while going around a rotary.
Old Mar 10, 2012 | 05:48 PM
Tried both methods and no noise and no play in the wheel. What else can it be brake pads? Just had new pads installed bout a month ago and there making noise when coming to a stop. Can one pad be sticking, had the rotors turned also, can it be that the rotors took a crap already? Thanks for the help
Old Mar 11, 2012 | 12:05 AM
If its grinding when coming to a stop, I would say pads OR rotors. I'd double check the pads first and make sure they are wearing evenly. If one pad on one wheel is worn than the other one, you most likely have a caliper problem. IIRC, if the rotors were really bad before them being turned, turning them may not have worked and you may have to just buy new ones (this i'm not 100% sure about but I seem to remember hearing that there becomes a point when turning rotors just wont work). Thats about all I got for ya, hopefully someone else will chime in too. But just to clarify, it is grinding when you turn AND when you are breaking??
Old Mar 11, 2012 | 10:09 AM
Yeah correct its grinds when i turn and when im breaking, same sounds like when your brake lads are really worn
Old Mar 13, 2012 | 08:28 PM
hey guys been a couple of days and the noise hasnt gone away now its noticable while going forward. more noticable while hitting 20 havent taken out the pads to check because brakes arent really my forte the only thing i havent conquered lol
Old Mar 13, 2012 | 08:36 PM
vexx786's Avatar
I get a noise when I turn my steering wheel from full lock left back to the center. It's a weird noise, not really a grindind. I read that it could be a strut mount. I jacked up my car and there was no play in the wheel so that may be it.
Old Mar 13, 2012 | 09:08 PM
i dont think mine would be a strut mount i would imagine what would more like a clunk this is grind like when you have really worn brake pads
Old Apr 15, 2012 | 05:40 PM
did you ever figuered out what it was? i had a mechanic cheked it out he said it was bad struts. havent installed my eibachs yet so i guess im just goign to get some tokico blues withc are way cheaper than autozone.
Old May 3, 2012 | 07:07 PM
hey guys still havent found the fix to my issue but i think i just may have. i was pretty sure it was a bad wheel bearing but but there no play in both front wheel. no clacking noise while turning so cv axles must ok. i was doing some research on youtube keeping in mind of what the mechaninc told me and came across an old guy who was explaining on what a bad strut mount symptom is. so im guessing that what i have. he explained that the bearing moves when the car is turned, and thats about the only time my car makes noise while making a turn. can this be plausable?
Old May 4, 2012 | 01:02 AM
Laevateinn's Avatar
No wheel end play doesn't always mean that your bearings are good Have you done a visual check in the cv boot and/or axle? Turn it into the extreme left or right to have a good look in the valleys of the boot. Is your steering rack good? Boots good? No leaks?
Old May 4, 2012 | 05:35 PM
sascuderi's Avatar
Try moving the rotor sheild away from the rotor--I just did it tonight and it fixed my metallic sound when turing to the left. Never know and an easy fix
Old May 4, 2012 | 08:29 PM
im goint to try that tommorow did you just use your hand to bend it slight back?
Old May 5, 2012 | 01:52 PM
sascuderi's Avatar
no, what I did is turn the wheel all the way to the right and then to the left to get at both wheels. I worked from the front of the car and placed a screwdriver between the inside of the rotor and the sheild. Then I just twisted the screwdriver pushing the shield away from the rotor. Worked like a charm!
Old May 5, 2012 | 02:01 PM
ShocknAwe's Avatar
Nobody mentioned it could be your steering rack. Those boots busted as well? If your dust shield was bent it would grind all the time not just when turning
Old May 5, 2012 | 02:46 PM
sascuderi's Avatar
my shield would only make a metallic sound when turning left-->resolved once I bent the sheild.
pears
Sep 18, 2015 05:25 AM
lrb6805
Sep 17, 2015 04:49 PM
LtLeary
Sep 14, 2015 12:33 PM
thenewguyy
Sep 12, 2015 11:12 AM
ballerchris510
Sep 11, 2015 05:29 PM
