Anyone with a cosmo pulley?
Old Mar 12, 2012 | 05:21 AM
Grand_hustle17's Avatar
Its been a while since being in this section so pardon my noobism with the 3.0's again lol... I have a 01AE and ordered a cosmo lightweight crank pulley, im only assuming that because the 5th gen uses the same pulley then its safe to say they use the same belts also???, is there anyone in here with the cosmo pulley and what belt size did you use??? thx
Old Mar 12, 2012 | 08:29 AM
seriously? lol
Old Mar 12, 2012 | 08:32 AM
aackshun's Avatar
Never even heard of the Cosmo pulley.
To find a belt size all you have to do is get a piece of yarn, run it around the correct pulleys, not too tight though, just about under a half of an inch of play, tie a knot, take the string off, cut it measure it, take it to your local auto parts store and tell em you need some belts, the rest is self explanitory.
And yes you can drive around for a little bit w/o the accessories, when my A/C+Alt belt broke I drove for about 4 miles to the auto parts store.
Old Mar 12, 2012 | 08:52 AM
SteveB123's Avatar
seriously? lol
No answer from the vendor?
Old Mar 12, 2012 | 10:24 AM
cashoit's Avatar
this.
Let the vendor tell u what to use.
Old Mar 12, 2012 | 02:48 PM
MAXIMA_STYLE's Avatar
If its not underdrive its the same size as stock.....you didnt say it was or not so to answer your question youd need to be specify that... but nonunderdrive is oem belt.obviously... underdrive...ask vendor...if no reply ask unorthadox racing what size belts theirs use and try a belt in that size
Old Mar 12, 2012 | 06:19 PM
its a tad smaller... its a canadian company... they sell way more than just pulley and not only deal with maximas... idk if many people heard of it before but a buddy is also using it on his 5.5 (they make em for 95-01, and 02-08) i believe... its $80 shipped vs unorthodox for like $200+ lol... (now lets see if ima really make these guys famous lol) ive purchased from these guys before, i bought one for my 5.5 when i had it... no complains from anybody i know with em (the few i know n read about)... ill just take it to the shop and ask em what belt should i use, or maybe even pay for the install
Old Mar 12, 2012 | 07:03 PM
Yea i had one on the se-l 99 but unsure.of the belt cause it has since been removed and stock put back on, but if you find out lemme know cause i may invest in another one soon
Old Mar 12, 2012 | 07:24 PM
good to know im not the only person to try this... ill try to keep you guys posted
Old Mar 12, 2012 | 07:44 PM
mrjasonlyrics's Avatar
I bought the one for the 6thgen and it's been working good so far. It's way lighter than the stock by far, as for the belts I had to go three size less smaller than the size recommended because it was tightened to the max and it was still squeeling. They provided two sizes and they both squeel after tightening to the max so I went one size smaller and it worked good.
Old Mar 13, 2012 | 07:28 AM
aackshun's Avatar
Awww chit... $80?!?!? I'm gettin it now.
Remember, the VQ30 is a well internally balanced motor, not a V8, do not apply 1950s concepts on this motor in regards to lightweight pulleys.
Kthx.
Old Mar 13, 2012 | 10:27 AM
Kthx.
I figured not a lot of people were aware of these as when you mention pulley all you hear is OBX and Unorthodox, i figure this was just as good... same weight i believe.. 1.5lbs not expecting any crazy gains maybe a 2-5whp bump to the peak side... i was talking to smokeVQ yesterday and he said he had to go with a size smaller than recommended also... smh
Old Mar 13, 2012 | 12:02 PM
SteveB123's Avatar
I guess that's the way to go, if the vendor refuses to answer your emails.
Old Mar 13, 2012 | 12:25 PM
aackshun's Avatar
To find a belt size all you have to do is get a piece of yarn, run it around the correct pulleys, not too tight though, just about under a half of an inch of play, tie a knot, take the string off, cut it measure it, take it to your local auto parts store and tell em you need some belts, the rest is self explanatory.
Old Mar 13, 2012 | 01:59 PM
hornepirate's Avatar
I was looking at one of these for a while but never got one because i was unsure of how reliable the cosmo pulley would be
Old Mar 13, 2012 | 04:05 PM
I sold a brand new one when i first got the car.. idk why i put stock back on...may have to invest in another...would compliment the lightweight flywheel good lol.. faster rev faster revs...faster time yaaaaa
Old Mar 13, 2012 | 04:09 PM
Just to throw it out there.. you can get obx udp on egay for 70 bucks...
Old Mar 16, 2012 | 09:16 PM
And $10 forba better brand... either or...
Got it today
Gonna start with same belts as unorthodox.. k060408 n k040292
Old Mar 17, 2012 | 10:18 AM
Update us how reliabillity is and fitment is with those belts
Old Mar 17, 2012 | 10:26 AM
IslandMax's Avatar
Ive heard that these sometimes wear out where the seal rides on the aluminum, unorthodox pulleys have a steel ring slipped over (where the seal is) so that there is no wear and no leaks. Do they make a stock size one? Price isnt bad.
Old Mar 17, 2012 | 11:25 AM
lol, well i can kinda give you that now as a buddy has one in his 5.5 going 6yrs strong no issues lol... this is my 2nd one, i had one for my 5.5 that didnt get installed thanks to the car being broke forever then sold
Old Mar 17, 2012 | 11:33 AM
dont really know much about the ones for the 3.0 but ive never heard of this problem.. im sure the seals would be a good replacement when doing these, who knows the person whoever had that problem may have already have a bad seal... i also had a motostorm one before they discontinued and it worked fine for me
Old Mar 17, 2012 | 11:37 AM
just picked it up, looks great
Old Mar 18, 2012 | 08:22 AM
RA030726's Avatar
I'm nutty for Nissans
Go to URs site to get the part numbers for the belts. I have some no name pulley and 2 URs. They are the same size so I'd assume this brand is just another knock off.
As for the oil seal issue make sure the snout of your pulley has a steel insert. If its all aluminum the seal will eat the aluminum and develop a leak.
The only difference on the 3.5l version is the lack of the crank sensor timing ring.
Old Mar 18, 2012 | 08:25 AM
RA030726's Avatar
Oh and lock tite the screws
Old Mar 18, 2012 | 08:46 AM
Rods03Max619's Avatar
Looks pretty much the same as my Ralco did, I used belts 048305... and 060431 Gates...
Old Mar 18, 2012 | 09:09 AM
ShocknAwe's Avatar
UD pulleys arent worth the hassle IMO but I def think they will give you a few ponies unlike what others think. Congrats on the new shiny thing
Old Mar 21, 2012 | 08:39 AM
well maybe not to most but this car cas 156K miles, im sure its almost time to change the belts and why not get a few ponies from doing so???
whats "UR's"???
Old Mar 21, 2012 | 08:46 AM
whats "UR's"???
Unorthodox Racing.
Old Mar 21, 2012 | 09:19 PM
The one on the site is wrong according tosmokeVQ who has a UR pulley, so I'm gonna mimic the same belt size assuming thy are the same..... K060408 and K040292 I believe... ordered both gates belts today so we'll see
Old Mar 31, 2012 | 05:57 AM
max1008's Avatar
Just got mine in today, will have it on in about a week. The paper that came with it tells you the belt sizes. Can anyone verify if its correct?
Old Mar 31, 2012 | 04:45 PM
aackshun's Avatar
Facepalm @ the belt questions..... I don't think you guys should be attempting crank pulley installs if the belt size worries you the most.
Just my 2cents.
Whenever things stop breaking on le white car I'll get around to getting this badboy for it.
Old Mar 31, 2012 | 06:09 PM
For my Motostorm Pulley used K040300 and K060408
Which pone do you have...
Just my 2cents.
I know huh, already got mine on and Damn love it, picks up on speed way quicker, other mods also helps with that....
Old Apr 14, 2012 | 06:46 PM
O.k so it was a warm 70* out n with the help of shiftmax_md I got aroun to installing the pulley, just got in the house n on the cell but to give this thread n update the install went pretty decent id say, the belts I had worked with no squeeling right now lol... it used the stock power steerin belt and (I actually can't remember the size I listed earlier for the AC n alternator, but it used 1 new belt n 1 OEM ize belt... had to fully take the belt tensioner off to get the belt to go on, fit tighter than a damn condom lol
Old Apr 14, 2012 | 06:48 PM
Overall feel of it..... I felt absolutely no power gain whatsoever lol not that I was expecting it to, I didn't realy notice a more responsive car but I will say my windows definately went down faster than before lol.... I'm sure it freed up 1 or 2whp but overall I'm happy with the install n mod
Old Apr 15, 2012 | 06:29 PM
max1008's Avatar
This with a lightened fly wheel will be the most beneficial. Can't wait for my LSD trannny to get in.
Old Apr 15, 2012 | 07:12 PM
This with lightened flywheel wont make much of a.difference either....nothing noticeable over just the pulley.. maybe with a bunch of supporting mods it will but i got lightweight flywheel and had a lightweight pulley...didnt even notice gains...im sure theres a few but nothing noticeable,but its nice and shiny
Old Apr 16, 2012 | 05:31 AM
max1008's Avatar
I have all the bolt ons but what you notice is a faster rev, if you are looking at a WHP jump you are looking at it wrong.
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
02PearlSE
Feb 1, 2016 12:37 AM
rbarnes
Dec 31, 2015 06:29 PM
DarjeelingRose
Sep 15, 2015 01:20 AM
