ddm tuning hid kit install issues
So i got a hid kit from ddm tuning (i know i know kill me now but my retrofit will be soon.) When going to install, i had the ballasts fully connected ready to plug in
Now this little blue piece
Is supposed to connect to this little black piece correct?
Anyways when trying to set it up it did not connect properly, it was very loose with the connection, it didn't just snap in, and when trying to plug it in, lights did not work. Am i doing something wrong here, i installed hids on my 06 altima just fine and don't remember having this issue, this is the 9004 kit from ddm, am i missing something?
Yes, connects to one of the factory connectors. I only have one connector, same blue one, that connects to one factory connector and the other factory connector doesnt connect to anything. You'll figure it out, not a million wiring options for headlights
but even when connecting it just to test it out to make sure the bulb lights it didn't work? and i don't think it'd be 9007 since i put in a 9004 bulb from auto zone a month ago
ok well you most likely have the wiring wrong. take them out of the blue connector by compressing the tab on the metal with a pair of pliers and have everything else hooked up and find a combination that works. My guess is going to be the 2nd and 3rd female ends on the factory connector. Wrap it in electrical tape when your done to keep water out as well, especially if its loose
inside of the blue connector there are 2 metal prongs, so 2 wires to the blue plug, and in the black connector for the harness it has 3 slots for 3 prongs, sound familiar? and it is a low beam only kit
On the blue connector, make sure the red wire is in the middle slot and the black one is in the slot on the right. If not, you'll have to switch them around. Search YouTube for how to re-pin a 9004 harness.
https://www.ddmtuning.com/support/in...emid=1&nav=0,1
and I used this
http://www.cumminsforum.com/forum/at...e-90049007.jpg
obviously we use the one on the left. also make sure the prongs in the socket are straight so they slide in.
and I used this
Easy fix! but you should've spent your $$$ on a Bi-Xenon setup....glareshields with xenon hi beams and xenon low beams....and just right for a halogen housing! Reduced glare and a true visible hi beam system!
ddm changed there kit so its a hid high beam not halogen now had them but didnt set it up on my car cuz i was thinking of retrofiting some projectors on to the cifero headlight assembly best part bout living in sd i can just drive up to ddm and return them at there shop
VQ'ed
69
Aug 27, 2020 12:29 PM
Finkle
Sep 27, 2015 09:53 PM
SmokinMax02
18
Sep 11, 2015 12:25 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
