Car not starting.....WHY?
Old Apr 28, 2012 | 05:48 PM
monist's Avatar
I have a 95 Maxima. It was running fine except it had a bad oil leak from the rear valve cover. I've got a couple of estimates and both around the $400 area. I've researched this forum and the web and decided to do the work myself. I've took everything apart and put it back together again. Then now the time of truth comes around, I try to start the car and it turns but won't start. I check the diagnostic codes and I've got codes 0101 and 1008. Would one of these codes make it not start or should I go back and try to redo all the connections and hoses. Maybe I missed something? Any suggestion on what to do? Thank you for your help.
PS. The car was running fine before I tried to fix it. Why did I mess with it!!!
Old Apr 28, 2012 | 05:52 PM
nostrixoxide's Avatar
Pull one of the coils out & see if your getting spark...
Old Apr 28, 2012 | 08:19 PM
Laevateinn's Avatar
Are your codes correct? There's a p0101 (MAF circuit/performance prob) BUT I dunno about 1008. There's a P0108 (MAP high input). Most likely a vacuum leak or incorrect connection. Try replacing all of 'em too.
Old Apr 28, 2012 | 08:48 PM
Your issue is the 0101:
Model Year : 1995
Flashing CEL code: 0101
OBD-II Standard P Code: P0340
Code Description: Cam position sensor
Old Apr 28, 2012 | 09:58 PM
2brosgixxer's Avatar
Model Year : 1995
+1 same problem with mine last week. Changed sensor and all good now.
Old Apr 28, 2012 | 10:10 PM
.. I'd fix the other code as well.
Model Year : 1995
Flashing CEL code: 1008
OBD-II Standard P Code: P0443
Code Description: EVAP Canister Purge Control Switch/Valve
Old Apr 29, 2012 | 03:29 AM
Model Year : 1995
Minor in the grand scheme of things since no driveability issues, but yes fix it. Pull evap Vent valve off charcoal canister via 2 10mm bolts, Check inside Evap vent Valve to ensure the plunger is moving when power applied and that it will move by inserting a screw driver and prying it. If it will not move freely, PB Blast it and let it sit to free the rust. Watch this video for the how to Vent Valve Fix
Old Apr 29, 2012 | 03:50 AM
DennisMik's Avatar
Check the wire harness and connector for the 0101 cam code before you get a new sensor and check that all the vacuum hoses have been reconnected to the solenoid valves by the front valve cover on the driver's side.
Old Apr 29, 2012 | 08:20 AM
MAXIMA_STYLE's Avatar
Car wont start because.it dont like you
DFoot1986's Avatar
I got a problem where I go to turn the key and nothing happens. Most likely the cam sensor, but could be any number of things. I'm just driving the damn thing as a daily driver till I go to arizona next April and get me a rust free 4th gen maxima. It still starts fine, just take a little teasing, thats all.
Old Apr 29, 2012 | 02:32 PM
monist's Avatar
Thank you guys for your help. I went and took the cam sensor out and cleaned it. I went and cleaned the 2 grounds up by the intake manifold. I took out that EVAP which
I saw the video what to do and did it to the tee. I put it all back together and guess what, it started right up. It is running like a champ and also no smoky oil leak. Thank you for your help. I'll try to help if I can one day also.
PS. ran the diagnostic check and just got 0505. Which means everything good.
Mo
Old Apr 29, 2012 | 04:12 PM
Cleaning the cam sensor may only work for a little while...that's what happened with me. Worked for about a week then it just would not start. Got one from a jy for $15 at that point. Glad you got your stuff figured out! Good luck.
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Balkins
Aug 12, 2015 06:39 AM
altome15
Aug 10, 2015 07:05 PM
