4th gen max a/c question
Old May 23, 2012 | 01:58 PM
sirposted's Avatar
ok i just bought this max se great car fresh swap lowered lip yellow fogs but the a/c system isnt hooked up the only hose i have is this one http://www.theautopartsshop.com/sear...h=FS/56909.jpg and i know i need this one http://www.theautopartsshop.com/sear...h=FS/56908.jpg now ware dose the one i need (the second pic ) bolt into. i know one end plugs and bolts into the compressor but ware dose the other end go?
Old May 23, 2012 | 02:02 PM
ShocknAwe's Avatar
Im pretty sure the second one you pictured is the L side hose and sits on the pass. side of the compressor in a vertical fashion. FSM will show you better than words can
Old May 23, 2012 | 02:03 PM
JNCoRacer's Avatar
Just the tip.
It connects to the evaporator coil. Its behind the glovebox, but the lines connect under the hood at the firewall on the passenger side.
Old May 23, 2012 | 02:06 PM
asand1's Avatar
If you are missing that hose, you will need a new dryer, as it will be saturated by the humidity in the air. There may be other contaminants in the system.
Old May 23, 2012 | 02:10 PM
ShocknAwe's Avatar
A/C systems are kind of hard to deal with yourself. I don't understand half of it but then again I haven't had trouble with mine enough to have to figure it out
Old May 23, 2012 | 02:27 PM
sirposted's Avatar
''dryer''?
Old May 23, 2012 | 02:28 PM
sirposted's Avatar
fsm?
Old May 23, 2012 | 02:59 PM
dsonnylal's Avatar
Originally Posted by sirposted
fsm?
Factory Service Manual
http://www.nicoclub.com/FSM/maxima/
Old May 25, 2012 | 08:06 AM
metalgod3082's Avatar
Dryer is a small canister (looks like a coke can only a little taller) near the battery. Anytime the A/C system is opened that needs to be replaced as it absorbs moisture in the A/C system and it is probably no longer any good. Your A/C would probably still work ok without replacing it but it will definitely not be as efficient and it is only like $10 on rockauto.com. So once you replace the one line you need and the dryer, then you need to evac the system which you can rent the vacuum pump at autozone, and then recharge (preferrably with U/V dye in the refrigerant so you can see if anything else is leaking).
Finkle
Sep 27, 2015 09:53 PM
95Maxi
Aug 25, 2015 08:01 PM
MaxStock
Aug 12, 2015 08:33 AM
MikesChevelle
Aug 10, 2015 10:53 AM
ViciousVQ30
Aug 5, 2015 05:40 PM
