alternator misdiagnosed as faulty
My 2002 max.lost power and died due to low battery voltage Told I needed to replace alternator
Will cut a long story short. It turned out to be a poor connection at the plug that goes into alternator beside the main cable connection This will cause the alternator to stop charging and not let the battery warning lite activate
I removed and cleaned the connector with contact cleaner now everything is ok
I found this out by following the diagnostic procedure 1 in the charging system section of the electrical FSM
Hope this helps some of you to avoid wasting money on unnecessary replacing an alternator
ps prior to this I had experienced the battery light sometimes flickering when driving
Yeah this is sort of common sense but it is awesome to see a new user post something a little useful!
A couple of weeks ago the same thing happened on my 04 passat. Mechanic wanted $800 to R/R. I took it out and the plug snapped. $50 later all was well.
TallTom
57
Oct 14, 2025 05:16 PM
it would have been very easy to assume it was the alternator, good catch.
