Car Won't Start
Old Mar 15, 2013 | 08:03 AM
SubliminalSam's Avatar
Car Won't Start
Hello,
So i have a 2000 Nissan Maxima gle and recently I was driving it and I was having trouble accelerating, I would press on the gas and it would take a moment before accelerating and a few times wouldnt go past 45mph. The next day I had trouble getting it to start up, when it did It ran fine and then stalled on me at a red light. Yesterday I drove to a friends house with no issues then when I got ready to leave gave me the same issues when trying to start it, finally it started but stalled on me before I left the parking lot, It does start for a few seconds then sputters and dies again, I ended up pushing it to a parking spot and had to leave it there. I recently changed a bad ignition coil, and changed my MAF sensor a few years back, I dont know how long they last but I would imagine that it is something aside from those two parts. I have searched the forums and Haven't been able to find someone with symptoms quite like mine. Please any help would be appreciated.
Old Mar 15, 2013 | 08:04 AM
Amerikaner83's Avatar
when you changed your MAF did you go with genuine OEM parts? Your symptoms are describing a MAF issue...
Old Mar 15, 2013 | 08:28 AM
No I believe it was replaced with an aftermarket sensor.
Old Mar 15, 2013 | 08:41 AM
go OEM or go home with certain things...MAF being one of them. Go to a junkyard and find one there, maybe in the classifieds here as well...
Old Mar 15, 2013 | 12:31 PM
CMax03's Avatar
Sounds like the Cam/crank sensors to me.....
Old Mar 15, 2013 | 03:13 PM
Pilm's Avatar
No codes? Without codes it's a guessing game, maybe this, maybe that...
Old Mar 20, 2013 | 06:15 AM
So i had a mobile mechanic come out and read the codes, and an MAF code is coming up and primary ignition coil code is also coming up. He explained that I should have all of my ignition coils replaced along with my spark plugs, and possible my fuel filter, but I'd like to get maxima forums members opinions. Additionally I was able to get the maxima to start up again however I noticed black smoke coming out of my muffler when I tried accelerate so ultimately its parked again and Ill just have to have it towed. That guy may not have know what he was talking about, or perhaps my car isn't spitting out the code that will let me know what the real issue is. My question now is, is it normal for maximas to emit black smoke when its an issue with the ignition coils? Please let me know what you all think the underlying issue might be.
Old Mar 20, 2013 | 07:50 AM
If the MAF code is popping, replace the MAF. OEM, remember?
Ignition coils...it's a 2000 so the coils ARE suspect...but no need to get all 6 right now. You can wait until you get a better idea of which one is misfireing and replace that one. Go OEM on the coils too by the way. It's well known that aftermarket coils will throw a random misfire code.
Old Mar 20, 2013 | 08:27 AM
jomurill's Avatar
you can always try "seafoam" and clean the system that will also help getting rid of that black smoke
Old Mar 20, 2013 | 08:56 AM
OP needs to do other things, like get the car running without popping codes, before using seafoam.
Old Mar 20, 2013 | 09:21 AM
Pilm's Avatar
Totally agree, get the codes taken care of before doing anything else, and use OEM parts for MAF and coil packs. I'd also tackle the MAF first and wait on the coils, or buy one front and one back coil and swap em around till misfire goes away (most likely you just have one bad coil if this problem just started suddenly, they don't all go bad the same day). Also, buy a $25 code reader so you can check/clear codes yourself, and keep it in the glove box so you'll be ready whenever something happens.
Old Mar 20, 2013 | 10:12 AM
TunerMaxima3000's Avatar
Install an OEM MAFS. Common issue. Common also to have an aftermarket one be complete garbage even brand new.
The fuel filter is non-replacable on this car. It's actually just a filter 'sock' on the pump inlet inside the tank. It can be replaced but the chances of it being the issue are like 1%. Don't bother.
Old Mar 21, 2013 | 03:02 PM
one time I had the same issue, changed the verhooten valve and my piece of **** car never ran so good. those valves are expensive though, I had to perform oral sex to a transvestite midget, I said that a.t.m. was over paying, he/she agreed. oh and yes I left my computer on at work again.... I am sooo retarded! I have also been described as just smart enough not to **** on the floor!
Old Mar 21, 2013 | 03:37 PM
cjandura's Avatar
Tuner you need to keep your after hours activities you have with Litch and that bottle of maple syrup and strips of bacon off the forum brudder
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Btheman80
May 1, 2018 04:03 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
BobMax
Aug 15, 2015 12:35 PM
