KEYLESS ENTRY HORN, please help
hey guys,
My keyless entry works fine but it dosen't make that noise when you lock and unlock.I checked the horn and it works fine.
please help,
TIA
Jay
please help,
TIA
Jay
It should be easy to do...haven't done it myself though. All you would need to do is to wire in a relay from to your power door lock system (12-39) in the Haynes manual. Check what signals come from Data line A-1 and A-2. This should activate your door lock solenoids. Take power from your turn signals on page 12-33. Finally hook into the horn.
This is a quick and rather dirty way to do it Every time your signals ar blinking and you manually lock your door the horn will also sound....so it isn't the prettiest way.
Have to study it more to let you know better
Nigel, so does that mean when you put on your turning signals the horn will start going off? Cause that would be a pretty bad idea. Or did you just mean that when you lock your car and the clear corners blink that the horn would go off then.
So if your engine is running, your turn signals are ON AND you hit the door lock switch on the driver's side you would also trigger the horn...that's the only time it would trigger when you didn't want it to.
it's not pretty. If you can hook into the relay in the trunk that activates ONLY when the door lock is sensed, that would be the best. I will experiment when I get some time and let you know.
Originally posted by Scruit
There is a special relay in the trunk that the BCM computer uses to activate the turn signals when you lock with the keyless remote. You would have to study the wiring diagram to see if the regular turn signals would also trigger your audible signal.
This way you would only get the horn beeps when you activate the remote lock.
no flashing turn lights
my car is a 96 Maxima QX 3.0 with keyless entry, leather, sunroof, ...
Please help.
Markus
Re: no flashing turn lights
Originally posted by Eddi79
I have fund this relay in my trunk - but it doesn`t "klick" when I lock or unlock. Has anyone an idea why ? (also the turn-lights don`t flash when locking/unlocking). I`d like to have this feature (at least the turnlights flashing). What can I do ?
Please help.
Markus
Please help.
Markus
http://www.rcreations.com/public/CoD...e,0t,P=29.html
take care,
Jay
Re: Re: Re: no flashing turn lights
Hey my lights haven't flashed in months when I hit the lock button. could my BCM computer or what ever be messed up? How could I test. And where is that thing located. This is driving me crazy, I've left it aloen for a while but I would liek to have it working again. Thanks.
Re: Re: Re: Re: no flashing turn lights
ryan
ah2002
Mar 9, 2016 01:42 PM
