Possible to roll back a odometer cluster?
Is it possible to roll back an odometer cluster? I want to buy the se white gauge cluster, but I want my 42k miles on it. Is it possible to change it?
Re: Possible to roll back a odometer cluster?
Yes, the cluster can be disassembled and changed. If you do it, it's illegal. If you take it to a dealer or a speedo shop, you get a certificate that it has been changed and they charge you for it.
i just changed out a tach...bought a GXE cluster and put the tach into my SE cluster....i'll say this...the gauges aren't meant to take apart. Only way I could figure out to take it apart was to pry up on the pointer to pull it out of the gauge...it went back together and works....but not sure i would recommend it. This should technically be "legal" though as you are not tapering with the ODO.
NOTE: The SE white face doesn't have the screws pass through it like the black GXE/GLE gauges, so you also need to transplant the plastic bracket behind the face too!
after all this...sure sounds better to just buy a face kit off Ebay...
good luck
John
good luck
John
Also, sprint, i dont think the kit you buy looks the same. I want exact stock replica. Is it possible?
Justin Kroll
Sep 2, 2015 11:06 AM
