Rear suspension trashed (not struts)
For example in the pic of the Sentra before and after the Panhard install, the 1st pic says "Without the Panhard, using the OEM SRL", when it should "Without the Panhard, using the OEM SRL PLUS OEM RSB PLUS AFTERMARKET RSB"
The aftermarket RSB is plainly obvious in the picture. Given that setup, rear end lift as the result of 2 RSBs is inevitable.
In the after setup the SRL, captioned "With the Panhard" really is "With the Panhard PLUS OEM RSB." So now you have the OEM RSB working in conjunction with the Panhard rod..... with good results.
I had an RSB on my car but once I lowered it the RSB wasn't needed. I found the tail end of my car to be too hot with H&Rs and an aftermarket RSB. The Panhard article seems to bear out this observation.
Huttig2009
Sep 25, 2015 03:31 PM
CAN-Other LF: Worn / Broken Parts
george__
Aug 18, 2015 07:06 PM
