Tsb 97082797026
Tsb 97082797026
Searched the forum and still found no information on this TSB. Only found it mentioned without any reply. If anybody has a copy that would be awesome.
96 maxima stock
96 maxima stock
The TSB relates to the vehicle having a long crank time/hard start after sitting for 2-4 hours after being at operating temperature.
The problem that I am having:
After starting the vehicle and driving it will start normally unless i let it sit for 4+ hours. then it has a long crank time before firing up then back to normal.
i would check your fuel pressure, connect a gauge in series and let it sit, i shouldnt fall off, if it does crimp off the return line and see if it still persists, if it does i would say the anti drain back valve in your pump assembly is bad.
if you crimp the line on the inlet after and it loses pressure, i believe the FPR is bad, someone correct me if im wrong.
Classification:
EC97-026
Reference:
NTB97-057
Date:
September 15, 1997
1995-97 MAXIMA INTERMITTENT NO START
This bulletin supersedes NTB96-103/EC96-012 dated October 23, 1996. Please discard NTB96-103/EC96-O12.
APPLIED VEHICLE:
1995-97 Maxima (A32)
APPLIED VINS:
Vehicles built before JN1CA21D8VT833870, JN1CA21D1VT215614 and JN1CA21D5VM510709
APPLIED DATE:
Vehicles built before December 10, 1996
SERVICE INFORMATION
This is not considered a product campaign; normal warranty conditions apply. Please refer to your current Flat Rate Schedule (FRT).
If a 1995-97 Maxima has difficulty starting after 2 to 4 hours cooling from operating temperature, or after an overnight cold soak at elevations above approximately 5,000 feet and ambient temperatures below approximately 40°F, the cause may be an over-rich fuel mixture during cranking. The engine will start after a long cranking period.
SERVICE PROCEDURE
1. If you can verify the incident with the conditions listed above, follow the diagnostic flowchart (cold engine, normal cranking speed).
2. Make sure the base idle is correct (see the flowchart).
3. Replace the engine control module (ECM) only if no other trouble is found. Use the chart for the correct part number.
Service Procedure "A"
If the vehicle cranks at normal speed but does not start when warm or hot, check the fuel injectors for leakage using the following procedure:
1. Release the fuel pressure.
2. Disconnect the fuel hoses between the fuel filter and the fuel tube.
3. Install a fuel pressure gauge between the fuel filter and fuel tube.
4. Clamp the fuel return line after the fuel pressure regulator. Be careful not to damage the hose.
5. Turn the ignition key to the "ON" position. You may need to cycle the key on/off several times to build up pressure in the line. Wait five seconds after turning the key off before repeating the cycle.
6. Clamp the inlet fuel hose just before the fuel pressure regulator.
7. Note the reading on the fuel pressure gauge.
8. If the pressure drops to almost zero within 1 minute, remove the fuel tubes with the injectors installed and repeat the test to isolate a leaking fuel injector.
WARNING : Be sure workshop has a CO2 fire extinguisher. Keep open flames and sparks away from work area.
CAUTION : Before removing fuel line parts, carry out the following procedures:
^ Put drained fuel in an explosion-proof container and put the lid on securely.
^ Refer to "Changing Fuel Filter" in the MA section of the service manual.
^ Disconnect the battery ground cable.
^ Do not kink or twist tubes when they are being installed.
^ Do not tighten hose clamps excessively to avoid damaging hoses.
^ After installing tubes, run the engine and check for fuel leaks at connections.
9. Replace any leaking injectors and reassemble.
Service Procedure "B"
Service Procedure "C"
If the vehicle cranks fast as if it has no compression when cold, perform a cylinder leakage or compression test to verify compression loss. Compression test results of 160 psi or less may indicate carbon deposits on the valve seats. If a cylinder leakage test is performed, the front O2 sensor may be removed to listen for leakage past the exhaust valves of # 2, # 4, and # 6 to confirm this condition.
If you can confirm this condition, install C/M starter P/N
23300-31U01R. This starter has 10 teeth on the pinion gear to crank the engine faster, restoring the sealing at the valve seats more quickly. If the no start incident cannot be duplicated, but the customer describes that the engine cranks fast as if there is no compression cold, install the C/M starter. This C/M starter was applied to production on December 8, 1995. Check the "Base Idle Speed" using CONSULT (Work Support, IACV-AAC Valve Adjust) and adjust to specification if necessary.
Information for Customer
A no start condition is sometimes preceded by a driving cycle of very short duration (less than one minute). The no start incident may occur on the next starting attempt. Should this pattern be observed, the vehicle can be started by holding the throttle wide open and cranking until the engine starts. Never crank for more than 10 seconds, or the starter may be damaged by overheating. During cold weather, Nissan suggests the following procedure to make starting the vehicle easier when this incident occurs. This method is an expansion of the procedure outlined in the owner's manual and should be used to remedy a "no start" condition when ambient temperature is low.
1. Depress the accelerator pedal approximately 1/3 of the way to the floor.
2. Hold the accelerator pedal in this position while cranking the engine.
3. Once the engine has started, release the accelerator pedal. (Do not race the engine while warming it up).
4. If the engine does not start within 10 seconds, wait at least 10 seconds before cranking the engine, again repeating steps 1 through 3.
Once a vehicle is started, in cold weather conditions, the engine should be run for a minimum of two to three minutes before shutting it off. Starting and stopping the engine over a short period of time may make the vehicle more difficult to restart. This type of usage may also adversely affect a vehicle's fuel economy.
Another factor which may affect a vehicle's "startability" is the viscosity or thickness of the oil that is used. An API SG quality, SAE 5W-30 is the preferred engine oil, all year-round for most models. In colder weather, oil that is rated as 5W-30 will not thicken as much as a 10W-30 rated oil; this makes it easier to start the engine and maintain a stable idle during warm up.
PARTS INFORMATION
CLAIMS INFORMATION
When applicable, standard claims coding applies.
© 2014 ALLDATA LLC. All rights reserved. Terms and Conditions
EC97-026
Reference:
NTB97-057
Date:
September 15, 1997
APPLIED VEHICLE:
APPLIED VINS:
APPLIED DATE:
SERVICE INFORMATION
SERVICE PROCEDURE
PARTS INFORMATION
CLAIMS INFORMATION
Just an update, I checked the Fuel lines and found a kink in the rubber hose from filter outlet to engine. Fixed the kink and replaced starter. Fired up on 2nd revolution. I will confirm that its fixed if it does not go back to the long crank tomorrow after it has sat all night.
doctorpullit
Oct 11, 2015 10:28 AM
punkdork
20
Jan 17, 2001 07:26 PM
