Nissan limiting throttle to protect CVT??
Old Sep 7, 2014 | 09:35 AM
CorollaULEV's Avatar
Ok folks - someone needs to explain something to me.
Are we are saying that the 9th gen Maxima (all years??? 09 and up???) limits the throttle up to ~30mph? As in - even though you stomp the gas pedal to the floor off-the-line, it never actually gets to WOT until ~30mph?? Nissan limits the throttle off-the-line to protect the CVT - in theory??
My 2010, when pegged, reads 88.4% throttle - that's WOT.
I knew that mine goes WOT before 30mph, but couldn't tell exactly when, so I checked it out yesterday.
I brake torqued it. Held the brake and hit the gas pedal to the floor. Speed is 0.0mph and throttle immediately goes to 88.4%. It goes WOT at 0mph.
How exactly is this Nissan detuning the car to protect the CVT??
Late,
Trav
Old Sep 7, 2014 | 09:49 AM
Mick7's Avatar
It is probably the CVT starting in a numerically lower..therefore higher...gear as in... it starts in second gear by conventional computer automatic transmission standards and gradually slides into a more torque friendly ratio at about 30 mph. There is no doubt at all that the car is sluggish from 0-30. Why? Have any tuners looked at the CVT as the culprit?
Old Sep 7, 2014 | 11:33 AM
Akiyukio's Avatar
Late,
Trav
You have the 9th generation Maxima? Sweet!
What numbers are you reading? I think there is more than just one number, one is actual throttle, the other is calculated/commanded throttle, if I remember correctly.
Here is the other thread for your reference: https://maxima.org/forums/7th-genera...bove-80-a.html
Old Sep 7, 2014 | 12:18 PM
BAAHAHA! The 9th gen looks just like the 7th gen. I know cause I gots one. LOL. Oops - used to own a 9th gen Corolla....hence the screw up.
I am looking at relative throttle position. There is also an absolute throttle position. The only difference between the two is that absolute is what the ECU sees as a result of the voltage (it's a 5V scale so 5V is 100% and we'll say 1V is 0%) whereas relative is based on the "learned" throttle position because the two are rarely the same.
If it says 88.4% at WOT, then 88.4% is wide open (at least on my car). Yours will be different, as this is a learned value and won't be exactly the same between two more-or-less identical engines.
The engine rpm at WOT should be 3200-4100rpm at 25mph and 4700-5600rpm at 37mph. That's how Nissan designed this car. It's not because it's limiting the throttle, the CVT is just designed like this.
Old Sep 7, 2014 | 01:28 PM
Red4drSE's Avatar
uprev tune with ETC delete
Old Sep 8, 2014 | 07:46 PM
Does what? Wide open throttle is wide open throttle...the Maxima only limits it upwards of 85mph.
jfl330
Sep 4, 2015 01:44 PM
DrVee
Sep 4, 2015 12:18 PM
crazyespn
Sep 3, 2015 01:30 PM
Justin Kroll
Sep 2, 2015 11:06 AM
coasterswim
Sep 2, 2015 07:43 AM
