Remote Line...
Old Jan 25, 2002 | 02:29 PM
PhantomMenace's Avatar
Remote Line...
Does anyone know offhand which wire I should tap to to get this signal to my amp??
Thanks,
Phantom
Old Jan 25, 2002 | 02:30 PM
SuDZ's Avatar
I forget what the purpose is of the remote line... is it for power?
SuDZ
Old Jan 25, 2002 | 02:32 PM
Power...
SO the amp isn't constantly on. It can only be on, when the car is on.
Old Jan 25, 2002 | 02:49 PM
SuDZ's Avatar
oh yeah. I remember i hooked it up on my older cars to the power on the radio. It went on and off with that. Also since it was hooked up to the radio when it was off so was the power.
SuDZ
Old Jan 25, 2002 | 07:13 PM
phatmax95's Avatar
yeah, but make sure you dont hook it to the CONSTANT 12V power wire going to the cd player, this would cause it to be always on. i think there should be a remote turn on wire - in most cases it will be a blue and white wire
correct me if im wrong
Old Jan 25, 2002 | 07:25 PM
95emeraldgxe's Avatar
what are u doing exactly? - new system?? or u just making a few minor mods?
Old Jan 25, 2002 | 07:29 PM
Adding Subs and amp...
I have the remote going to the wrong blue wire, Its stays on constantly. I'm goin tap it to the other blue wire and see what I get. The Amp is in the trunk, so I had to run a wire up to the dash. the power and groud are all ok, and connected good. Fused off, distribution block, etc, just didn't want to hit the wrong wire for the remote, which happened anyway!
Thanks,
Phantom
Old Jan 25, 2002 | 07:33 PM
maximus75's Avatar
You can also use a "key on" wire or a power ant sig wire.
Old Jan 25, 2002 | 07:47 PM
Do you know what colour this wire is, under the steering column??
Old Jan 25, 2002 | 08:07 PM
Ravq's Avatar
Maybe this will be of some assistance:
http://www.installdr.com/InstallDoctor/QuickWiring.html
Old Jan 25, 2002 | 10:48 PM
JdawgX's Avatar
Are you using an aftermarket HU? Or the stock one? And you can leave the tap hooked up where you have it now if you want. You just need to intall an on off switch in lione somewhere and then remember to flip it off when you're not using it. It's pretty simple to do. E-amil me if you decide to do it and need help.
Old Jan 26, 2002 | 02:44 PM
maximus75's Avatar
Just use a testlight. Any wire that has power with the ignition in acc and on will work.
Old Jan 26, 2002 | 02:54 PM
Yeah, I did that... its all good now... but I have bigger probs now.. might be the altenator needed to be swapped.
-Phantom
Old Jan 26, 2002 | 02:58 PM
maximus75's Avatar
-Phantom
OOOOhhhh no
lowpost99
Oct 26, 2025 06:53 PM
ToTheMax305
Sep 23, 2015 09:11 PM
flu2000
Sep 14, 2015 12:34 PM
intimidator
Sep 5, 2015 07:23 PM
