Non-HID 2012 Maxima H11B | XB35 or XB55?
About to pull the trigger on some morimoto's:
Quick Questions:
Canbus Harness - Included - Needed?
Relay Harness - Adding to order!
And Last but not least 55W or 35W -- Stock non HID lenses.
Thanks!
Quick Questions:
Thanks!
here is the link in case anyone is interested:
http://www.ebay.ca/itm/H11B-XB-5500K...item5d53ab08a2
This is the kit that i used in my car. Now the bulbs that come with the kit have the ground wire shadow. It does not bother me because anything over the stock halogens are 100 times better and I went with the 5000K color. The relay kit comes with this setup also. I did not use mine and have had zero issues with the kit. Enjoy being able to see at night
https://maxima.org/forums/7th-genera...d-install.html
That is the H11B kit though (which means the ground wire is on the bottom) so I should be safe there -- so you dont have the canbus adapter correct? I am getting the relay kit.
Are your xb35 or xb55 ballasts/bulbs
Im pretty sure, that's because you don't have the relay installed -- im pretty sure thats what makes sure your ballasts don't burn out.
I manually trigger my lights though because I love to turn on my fogs with my lights
As long as you have the newest ballasts from morimoto which have the lower starting current draw, the auto on function should work 100%. When i had the older morimoto ballasts, the auto on function only worked half the the time (only one light would come on). Also, the xb35 bulbs still have a shadow effect.... its not as distinct as the h11's but the light is definitely not uniform. Most people wouldn't notice though...
The stock HIDs that come on the Maxima have a shadow effect as well, but you do not notice it unless your car is facing down on an incline as the headlights and its intensity is directly within 15 feet of the car.
As long as you have the newest ballasts from morimoto which have the lower starting current draw, the auto on function should work 100%. When i had the older morimoto ballasts, the auto on function only worked half the the time (only one light would come on). Also, the xb35 bulbs still have a shadow effect.... its not as distinct as the h11b's but the light is definitely not uniform. Most people wouldn't notice though...
Up is bad, down is better -- do I have that right?
Also should I go 35W or 55W on the lows -- I dont want to be a d1ck with super brights, but haven't seen anyone to ask locally about what they put in theirs to see 'in real life'
Thanks for the info man, which current draw is the right one, and your last point there confused me a little bit, isn't it the H11B's that I want?! that place the ground wire on the bottom, or do I want the H11's with ground wire up.
Can you check my ebay link 2012maximaS, I could ask the seller myself I just dont now if they are the 'new' or 'old' style. I believe the listing lists the current draw, could you compare to yours, I am low on cash (aint we all) and want to make sure I get the good stuff for my money...
Thanks in advance dude!
The 4500K Morimoto XB35 bulbs will offer the brightest output as well.
Thanks alot for the input Daver -- question is do they ship to Canada. if they do....
Im in! Ill check now thanks for 'codez'
(I have a friend named Daver im calling you that from now on haha, unless you object. And sorry for putting in a stackoverflow codez joke in there -- Im a SQL Programmer)
With that said I still love my hobby which is messin with cars -- my pops was a mechanic for 20 years.
Nintensity
Aug 13, 2015 05:41 PM
