How much am I expecting for labor?
Old Feb 9, 2016 | 01:12 PM
ljAiz's Avatar
It has been a little more than 5 years when I got my 5.5 gen. Found out recently that my rack and pinion is leaking, throw out bearing is going, cv axle need to be replaced, motor mounts are shot and a bad hub bearing. I already got all the parts in hand, I just need to bring it to a shop to install it. The first shop I went to quoted me $1,500, is that what i should be expecting or is it a little excessive for just labor?
Parts that I got are
Napa reman rack and pinion
Both driver and passenger side cv axle
OEM power steering pressure hose and return hose
OEM Master and slave cylinder
OEM Throw out bearing and fork
SS clutch line
Moog Outer Tie rod , endlinks, and lower control arm
SKF Hub and bearing assembly
Energy Suspension Motor mount, subframe bushing, front sway bar bushing
Jim Wolf Technology Clutch and flywheel
Old Feb 9, 2016 | 01:45 PM
Child_uv_KoRn's Avatar
Bad *** Newb
SS clutch line
I bet someone would tell you over 1,500 and closer to 2. You better find a discount rate.
If you're disassembling all that...I sure don't see headers in the list. Steering rack shmeering rack.
Old Feb 9, 2016 | 01:46 PM
IsaacFall's Avatar
I don't know exactly how much all that would cost, but $1,500 sounds like a pretty good deal to me.
Old Feb 9, 2016 | 02:19 PM
ljAiz's Avatar
Thanks for the input and opinion, if $1,500 is what is worth then I'm not too upset about the price.
Header was pretty much the first thing I did when I got the car lol
Old Feb 9, 2016 | 03:36 PM
Derrick2k2SE's Avatar
While they're in there you may as well have them replace the rear main seal. If it's not leaking yet it probably will be soon. It is some extra work but with the tranny already out it makes sense.
Old Feb 9, 2016 | 03:37 PM
Bad *** Newb
yay Would be a shame to replace all that stuff and lose the motor.
Old Feb 9, 2016 | 05:41 PM
ljAiz's Avatar
Yes sir, I got that part as well just forgot to mention it in the post
Old Feb 9, 2016 | 07:22 PM
Good deal.
Just out of curiosity. How many miles are on the car?
Old Feb 9, 2016 | 11:58 PM
ljAiz's Avatar
Good deal.
Just a little over 118k
Old Feb 10, 2016 | 09:20 AM
If the labor cost also includes the main seal that's even better. Even with the tranny out they still have to pull the Y-pipe and both oil pans.
One more thing. Make sure they use a good RTV on the oil pans since they don't use gaskets. The main seal will come with some RTV but I'd spend the money on a tube of Hondabond and bring it in.
Old Feb 10, 2016 | 11:17 AM
maxinout93's Avatar
that car should last you a while since you are putting a good bit of work into it.
bbsitum
Mar 4, 2025 04:27 AM
2014Maxima
Dec 22, 2015 09:41 PM
uttadms31
Dec 21, 2015 03:06 PM
5thgendriver
Dec 15, 2015 01:31 PM
tobyhatesmemes
Dec 10, 2015 03:52 PM
