2014 AUX noise
Old Feb 15, 2016 | 01:41 PM
mattfoley420's Avatar
2014 AUX noise
Hello all i have an issue with allot of noise over the speakers when i use AUX. This even happens when nothing is plugged up to the aux, also i do not have any car chargers plugged in as well. I just ordered a ground loop isolator as a last resort... Any thought s are appreciated THANKS.... BTW 2nd maxima for me traded my 08 in last year ..
TRIED
2 Bluetooth adapters
2 diff cables
Sound happens at increased volumes even if nothing is plugged in or playing..
TIA
Old Feb 15, 2016 | 02:30 PM
Nopike's Avatar
Sounds like you need to check the cars aux cable that runs from the center console to the head unit. It may not be plugged into the head unit properly. If it's not the cable it may be the head unit.
Old Feb 16, 2016 | 06:44 AM
Aux noise
Thanks for the response, the unit is factory no aftermarket... wouldn't it be soldered ? TIA
Old Feb 16, 2016 | 07:19 AM
Nopike's Avatar
It uses plugs it is not soldered. Not sure if you have Bose or other factory radio. Regardless, if the plug at the head unit were an issue you would probably have additional problems. Your best bet would probably be to access and check the aux connector at the center console going to the head unit as best you can. There does appear to be an additional connection between the aux connector and the head unit. I'm not sure where that is located.
Old Feb 16, 2016 | 07:21 AM
Nopike's Avatar
You can find all the information you may need in the FSM it is in the AV section.
http://www.nicoclub.com/FSM/Maxima/2014%20Maxima/
Old Feb 16, 2016 | 07:22 AM
Aux noise
Thanks a bunch I do have the Bose unit without navigation, Ill see if i can go on a wire hunt lol THANKS AGAIN
soldierp91x
Jan 17, 2024 09:14 PM
Pnjboyzz
Jan 5, 2016 09:44 AM
rquincoces
Jan 3, 2016 11:09 AM
Trickey79
Dec 30, 2015 05:21 AM
Liu Kang
Dec 28, 2015 04:45 AM
