need help diagnosing starter issue
sometimes the starter does nor engage and all I get is a click
it happens rarely and usually will then engage and start right up on the next try or two but this morning I had to try ~ a dozen times before it engaged, so i'm getting concerned (don't want the wife to have any issues when she uses it occasionally). since I hear the click and all dash-lights go off, i'm thinking that it's not the solenoid and the battery is tip-top for sure; I also have additional grounds all around (and to starter) so i'm wondering if this indicates starter needs a re-grease or is the starter on its way out. car has ~ 190k and this is the second starter (a reman was put on by dealership at ~ 135k in 2007). I've recently put shims into the ignition switch but that didn't seem to fix this issue. thanks in advance for any assistance.
If your battery, grounds and ig switch are all known good then your starter is on its way out. Pretty typical symptoms at least from my experience. Hopefully you got a lifetime warranty on your starter and you are just out the time to swap it out.
Nissan will not sell a reman starter, new or nothing from them. It's a crap shoot with any parts house starter. If you go the reman route get one with a lifetime warranty so the next time you are only out your time. I've had to do this with my Advanced Auto Parts starter FWIW.
Had the same problem. If it's still clicking you should be able to get it to start by trying enough times. Eventually mine stopped clicking at all and had to replace it with this from
. Easy enough to do myself. Works great, haven't had a problem yet after 3 months.
trentonlambert
Jan 31, 2016 11:38 PM
DjSinikal
Jan 29, 2016 12:39 PM
DeusExMaxima
Jan 29, 2016 12:36 AM
Maxima 97 SE
Jan 27, 2016 09:38 AM
