2000 Infiniti I30: Tranny Fluid Question
Old Feb 27, 2016 | 02:47 PM
desktop's Avatar
Got a 2000 Infiniti I30 and the tranny fluid on the stick is about an inch above the H mark. Anyone know where I could access a line/hose so I could drain some of it and not have to climb under the car to drain it from the pan?
Thanks.
Old Feb 27, 2016 | 03:33 PM
mclasser's Avatar
I overfilled the tranny once and used a small siphoning bulb from Walmart to extract the excess through the dipstick tube. The tube diameter is tiny in these cars and that was the only thing I found that fit. It took about 15 messy minutes to get out 400 mL of fluid so be prepared.
Are you checking the fluid level according to the steps in the manual? If you're checking it after a long highway drive, it'll read high.
Old Feb 27, 2016 | 07:38 PM
desktop's Avatar
It reads at that level whether its warm or cold. I'll have to check into finding something to siphon the fluid out of the dipstick tube. Thanks for the tip
Old Feb 28, 2016 | 04:16 PM
QueensMAX's Avatar
take out the air vent and unhook one of the cooler hoses from transmission. Place the hose in an empty bottle and start the car for a few seconds and it should pump out a full quart.
Old Feb 28, 2016 | 04:26 PM
Child_uv_KoRn's Avatar
Bad *** Newb
Yep, same way you change the fluid.
Nearly every auto I've ever checked is overfilled and have been for many 10s of thousands of miles. Unless it's egregious, I don't even bother to correct it.
Pnjboyzz
Dec 19, 2016 10:32 AM
MAXSE5SPD
May 12, 2016 10:01 AM
MAXSE5SPD
Bornwired
Mar 1, 2016 05:24 PM
reallywildstuff
Feb 25, 2016 12:10 PM
