2000 Infiniti I30: Tranny Fluid Question
Got a 2000 Infiniti I30 and the tranny fluid on the stick is about an inch above the H mark. Anyone know where I could access a line/hose so I could drain some of it and not have to climb under the car to drain it from the pan?
Thanks.
Thanks.
I overfilled the tranny once and used a small siphoning bulb from Walmart to extract the excess through the dipstick tube. The tube diameter is tiny in these cars and that was the only thing I found that fit. It took about 15 messy minutes to get out 400 mL of fluid so be prepared.
Are you checking the fluid level according to the steps in the manual? If you're checking it after a long highway drive, it'll read high.
Nearly every auto I've ever checked is overfilled and have been for many 10s of thousands of miles. Unless it's egregious, I don't even bother to correct it.
MAXSE5SPD
05-12-2016 10:01 AM
reallywildstuff
02-25-2016 12:10 PM
