2003 GLE P0011 and P0021 codes!!!!!!
Old Mar 24, 2016 | 06:59 AM
Sam Maxima's Avatar
Hi guys as the title says I have a codes on my 03 last night,and cars is sluggish and the idles like @ss.Any help would be appreciated.I was thinking to just removed both cam sensors and maybe clean them?
Old Mar 24, 2016 | 09:05 AM
Brudface's Avatar
Not very fun codes in my experience. Could be a couple things, like they actually are blocked OR it could be that the oil passages leading to them are filled with crud.
Go out and by some Seafoam, put HALF of it in the oil, let it run for a good 25 miles or longer depending on how its actually driving. Also buy some brake cleaner as you'll need it for the next step. Take BOTH actuators off and CLEAN THEM REALLY WELL. when you take them off you'll notice that they have little screens in the input portion of them. Now while they are off drain the oil. Take what's left of the brake cleaner and spray it into all of the passages leading to the actuators. Let all the crud drain out then take your oil and put ONE liter in without placing the drain plug back in to make sure all of the brake clean actually came out.
Fill the oil, and put the actuators back on. Clear the codes before starting the car.
These codes may also be caused by faulty cam/crank sensors or the actuators NOT actually working. While they are off you can test them by sending a 12 volt signal to one lead and grounding the other, you should hear an audible click. The steps that I have laid out is the cheapest but toughest route. You also can just replace all three sensors with OEM ones at will but it's a touch more expensive.
Also to note that whenever you do an oil change IF you do them yourself is to always buy ONE liter extra and do a small flush with clean oil after you've drained everything.
Old Mar 24, 2016 | 10:26 AM
Sam Maxima's Avatar
Ok thanks for your reply Brudface-today I will try to take them actuators out and clean(on a side note-you referred the actuators are the ones on the corner of the valve covers?)
Old Mar 24, 2016 | 01:53 PM
Brudface's Avatar
Yes those are the actuators.
Old Mar 25, 2016 | 05:23 AM
QueensMAX's Avatar
First check oil level...usually low oil when both show bad.
Old Mar 25, 2016 | 06:36 PM
Sam Maxima's Avatar
I just did a oil change and oil level is full,but I did clean the actuators and clear my codes and so far so good!
Old Mar 25, 2016 | 06:38 PM
Sam Maxima's Avatar
Thanks a lot man-I did cleaned them up and put back-clear codes and drove like 50miles and I beat the crap out of it,no codes and she's running like a VQ again🙃🙃🙃
Aslinterpreter
Apr 6, 2016 09:46 PM
Kevin1960
Mar 19, 2016 05:54 AM
simpy49
Mar 9, 2016 06:57 PM
beechmon
Mar 6, 2016 06:58 AM
slickblack94
Feb 29, 2016 10:33 AM
