VLSD questions
VLSD questions
Hi everyone,
Hoping someone can clear up some questions I had.
I have the RE4FO4W but have seen this classified as RE4FO4V on AMSOIL and other product websites when I have entered my car info when searching for a full synthetic ATF, but assuming this is the same VLSD , or am I wrong?
Also, knowing that the difference between the 1998 Infiniti I30 and Touring is the Viscous Limited slip differential. I am surprised to see that the two share the same ATF classification of Matic D or Dextron III. I would assume some form of additive would have been necessary due to more moving , but also extend the life of the compared to a non-VLSD due to more pressure and requirement for higher viscosity for the VLSD to work properly.
Thank you!
Thank you!
Simply put, when you try to spin out on a snow-covered or wet street, to both front wheels pull?
I have a VLSD in my 98 GLE that I've been using the same fluid that I use in my I-30 non-VLSD for years without issue.
The main thing on a Nissan manual transmission from that era is to use a GL4 lubricant. I would look to keep the recommended fluid fresh over trying to change fluid type.
Here's some information on how to decode the VIN from the readme section.
How do I decode my VIN?
These are the items designated in the rows of the Vehicle ID Plate located on the passenger side firewall under the hood.
1-Type
2-VIN
3-Model
4-Body color code
5-Trim color code
6-Engine model
7-Engine displacement
8-Transmission model
9-Axle model
Body Color Code:
AL0 RUBY PEARL
AR2 CRIMSON BLAZE RED
AX5 NEW RED
BN6 STARFIRE BLUE PEARL
BT4 LAKESHORE BLUE
BV3 SATIN BLUE PEARL
CG2 PEBBLE BEIGE METALLIC
CP2 MAHOGANY PEARL
DJ2 BLACK EMERALD
DP0 DEEP EVERGREEN
DR2 SHERWOOD GREEN
EV0 SUNLIT SAND
FS0 SAGEMIST GREEN
KH3 SUPER BLACK
KN6 GRANITE PEARL
KT3 STERLING MIST
KV3 GRAY LUSTRE
LP0 PLATINUM IRIS
LS5 ROSEWOOD
LS6 CONCORD MIST
QN0 ARTIC WHITE PEARL (BASE)
QT1 ICELANDIC PEARL
Credit - jay_x
Need more help in decoding the VIN?
http://www.courtesyparts.com/specs/vin.html
This shows how to read the VIN for all the related vehicle info.
Credit: Deezo
So how do I tell if my car is Cali or Fed spec?
Raise your hood. Look for a shiny metal identification tag fastened to the passenger side of firewall. The top row is the Vehicle Identification Number, starting with J. The second row is model information. The first five characters are BLHUL. The 12th character is the destination:
N = Canada
V = California
U = US, not California
1-Type
2-VIN
3-Model
4-Body color code
5-Trim color code
6-Engine model
9-Axle model
Body Color Code:
AL0 RUBY PEARL
AX5 NEW RED
BT4 LAKESHORE BLUE
CP2 MAHOGANY PEARL
DJ2 BLACK EMERALD
DP0 DEEP EVERGREEN
DR2 SHERWOOD GREEN
EV0 SUNLIT SAND
FS0 SAGEMIST GREEN
KH3 SUPER BLACK
KN6 GRANITE PEARL
KT3 STERLING MIST
KV3 GRAY LUSTRE
LP0 PLATINUM IRIS
LS5 ROSEWOOD
LS6 CONCORD MIST
QT1 ICELANDIC PEARL
Credit - jay_x
Credit: Deezo
N = Canada
V = California
NISSANMAXIMA91
Nov 21, 2008 09:09 PM
Yourself
Dec 1, 2004 11:32 PM
nismo2020
Jun 30, 2004 07:16 PM
