p0301 code. Cylinder 1 misfire
Old Feb 5, 2018 | 11:27 AM
follyburr's Avatar
Over the weekend, my SES light turned on. I checked it and it read p0301. My spark plugs, NGK, have about 20k miles. The car has 209k miles. Is it safe to assume it is the coil pack or should i also purchase a spark plug and swap it since i'll be in there already? Also, what are your recommendations on coil packs. Rockauto.com has Hitachi as a favorite, or should i check junkyard for an OEM? Also, I might as well change Valve Cover Gasket right? Thanks!
Old Feb 5, 2018 | 11:32 AM
Tarzan's Avatar
Fist move the coil packs around 2 cylinders and see of misfire and code follow.
Old Feb 5, 2018 | 11:41 AM
follyburr's Avatar
okay, thanks
Old Feb 5, 2018 | 01:22 PM
follyburr's Avatar
Do you know if I can i access/remove the cylinder 1 ignition coil without having to remove the intake manifold?
Old Feb 5, 2018 | 02:15 PM
Tarzan's Avatar
You can't remove any of the rear bank coils/plugs w/o removing the intake on a VQ engine. Now that you asked, it's clear to me that considering the effort of removing the intake, you'd be better off just replacing the coil with known good. My apologies, I was confused thinking it was the front passenger cylinder you were talking about.
Old Feb 5, 2018 | 02:41 PM
follyburr's Avatar
Yea, i figured replacing the coil was a more convenient solution. That's why i figured I ask a second time. haha Thanks for the replies!
carrottop
Jun 9, 2011 11:06 AM
95seMax
Dec 26, 2008 04:50 AM
adithius
Jan 5, 2005 10:20 AM
Gotham
Aug 3, 2004 06:12 PM
