New LED step lights on 4th gen maxima
Recently bought these. They are a 194 bulb and the stock bulb was a 161. The website claims it can replace a 161 and only draws 1.1 watts. What do u guys think? And is this 194 led ok for replacing a 161bulb??
yes, it's ok. The original 194 &161 incandescent lamps are different brightnesses from each other. The led is probably brighter than either of the originals. When using an incandescent lamp and going to a brighter one is that you have to deal with more heat in a small enclosure. The heat from a led lamp is much less and is not a problem.
I found that Orielly's extra bright LED for 194, 168 bulb are brighter...Just replaced the courtesy lights and license plate lights with that O'rielly brand....also check out Xtralight.com for an entire interior/exterior LED kit...
It is type 6612.
http://www.superbrightleds.com/morei...-30mm-car/243/
If you get these, they will be so bright that you are blinded and cannot use the mirror.
http://www.amazon.com/iJDMTOY-Replac.../dp/B00MOYJ0YW
are we trying to help incoming planes land or something? what happened to stealth? i really don't want super bright leds all over my max, seems way overkill imo. now colored led's in the console, doors, etc, different story.
true true. But yes i dont like the bright led really. I recently replaced the step light. And all the leds in the car are dim. I have a dim map light and back. I just like a different color than a standard bulb haha. But i see your point. I dont like too much light, which is why i have tinted windows lol
It is type 6612.
mist max2000
49
Jun 2, 2010 08:12 PM
jsmithsole
104
Mar 8, 2007 02:42 PM
