)4 Maxima Cranks but wont Start
Old Jul 23, 2018 | 05:30 PM
Mike19852607's Avatar
My 04 Maxima originally threw a code for cam sensor bank 1. I changed the sensor.. ( Have used multiple....OEM and aftermarket) no luck. if I unplug bank 1 it will start and run in limp mode. I have tried changing all the spark plugs, all of the coils, changed the crank sensor also, replaced the starter, checked the wiring harness for imperfections. I am at a loss. I was just driving it one day and it just acted like it died. I have an extra ECU I picked up from the junk yard but there is no point in throwing it in because I would have to program t to the key and I am not sure that it is the problem. It is not throwing any codes now. I also grabbed a PCMfrom the junk yard. Does anyone know if that has to be programmed as well? Any help would be greatly appreciated.
Old Jul 31, 2018 | 09:34 AM
Davisnathan49's Avatar
Hey there!
I’m no professional by any means. No hate please.
have you checked fuel pressure?
The cam sensor: have you tested the old sensor to see if it was the issue? If you run a new sensor and still nothing it may be what the sensor is reading. Like a rotational magnet of some sort.
My diagnosis for a crank no start is spark check, air check, and fuel check.
Old Aug 2, 2018 | 11:30 PM
Costee's Avatar
Check the ignition timing. Might be off.
Old Feb 20, 2019 | 03:26 PM
illrooster5861's Avatar
are you sure you are replacing the sensor in bank#1? have you tried a non good sensor? ( not after market )
jahsheed
Dec 28, 2012 02:31 PM
walterh
Dec 30, 2009 07:13 AM
Tyrexx
Nov 17, 2006 07:54 AM
dude88888
Apr 27, 2006 11:06 AM
mechanicaljoint
Mar 29, 2005 04:28 AM
