Local 96 for sale
Old Aug 31, 2018 | 03:40 PM
Frank50e's Avatar
Local 96 for sale
As above owner says it needs a main crank pulley.Seems odd but my main question is are our cars interference motors.Has anyone ever heard of this problem?
Old Aug 31, 2018 | 03:57 PM
CS_AR's Avatar
Oh yea.. The crank pulley can separate. I've had a couple do that. A separated crank pulley just means the belt will not turn when the crankshaft rotates. In fact, on my last Maxima purchase, I went ahead and replaced the crank pulley because sooner or later the rubber damper will fail. The timing chain is steel. Yes our engines are interference engines.
Here's a picture of a separated crank pulley that I replaced a few years ago.
Old Aug 31, 2018 | 04:04 PM
Frank50e's Avatar
Interference
So what you are saying is even though they are interference the crank continues to rotate in time with the cam so no valve into top of piston action going on.
Old Aug 31, 2018 | 04:07 PM
Frank50e's Avatar
Crank pulley
So theoretically even though you’d have no power steering air or fan the motor still should start.
Old Aug 31, 2018 | 04:08 PM
CS_AR's Avatar
Correct. Also, the timing chain drives the water pump (behind the front timing cover) so if the serpentine belt breaks, the engine will not run hot. Eventually, you will drain the battery and the car will stop running.. But no engine damage will occur..
The timing chain and the water pump are behind the timing cover. Here is a picture with the timing cover removed.
Old Aug 31, 2018 | 05:11 PM
JvG's Avatar
JvG
It's possible that the seller thinks that this is a catastrophic problem. So he might sell it cheap.
That pully has nothing at all to do with valve timing.
No engine damage at all.
You just need to replace that pully with a new one.
Old Aug 31, 2018 | 05:26 PM
Frank50e's Avatar
Pulley bolt
I realize this is a tough question but how difficult is breaking the bolt that holds the pulley to break loose?Tips?
Old Aug 31, 2018 | 05:32 PM
Frank50e's Avatar
96 Maxima
He says if I have new fresh battery he will drive it here about twenty miles 142k looks clean no rust interior looks clean 142k.His ask is 800 deal or no deal?
Old Aug 31, 2018 | 09:06 PM
RA030726's Avatar
I'm nutty for Nissans
Use the starter to loosen the bolt. With a breaker bar on the crank bolt and the handle resting on the groung turn the key for a split second. Easy fix, could be a great buy.
Old Aug 31, 2018 | 09:58 PM
KP11520's Avatar
Don't know if you have an impact gun, but the bolt holding the pulley guns right off. Easiest way. Leave the belts on until you crack the bolt.
While there replace both belts since they have to come off and also do the front main seal (OEM). You're in that deep, so might as well. OEM belts and seal are very reasonable. YT has videos.
Old Sep 1, 2018 | 02:44 PM
Frank50e's Avatar
Harmonic balancer
Is it necessary to replace harmonic balancer too?
Old Sep 1, 2018 | 05:58 PM
JvG's Avatar
JvG
The pully IS the harmonic balancer.
Old Sep 1, 2018 | 07:10 PM
Frank50e's Avatar
Balancer
Well I sort of assumed that but they are sold separatly so that confused me.Gotta get a book.
Superduck
Sep 21, 2012 05:27 PM
Soaknfused
Sep 4, 2006 12:27 PM
tavarish
27
Jun 6, 2006 01:34 PM
Cosmo459sx
May 9, 2006 07:52 AM
Niku-Sama
Dec 21, 2005 12:47 PM
