97 Max, New clutch master, lines, slave, clutch won't disengage
Old Sep 17, 2018 | 05:26 AM
mblakney's Avatar
I was out driving and noticed my clutch was feeling odd. When I stop to turn a corner, the pedal went to the floor and I couldn't shift to any gear. The clutch master was out of fluid. I refilled it and after about 10 mins of pumping I got enough pressure to get it home with all gears working. I later found the lower hydraulic line at the slave had bubbled and burst behind the banjo fitting. I replace the clutch master, slave cylinder, upper and lower hydraulic lines and bled it with a vacuum rig and manually but can't get enough pressure to move the clutch fork to disengage the clutch now. I know the master is not blocked because I see the fluid rise in the bowl when I compress the slave cylinder. The clutch fork moves freely with no pressure on it and doesn't when there is pressure on it but not enough to disengage the clutch. I even tried to move the clutch fork with a pry bar with no luck. Is it a bad clutch?
Old Sep 17, 2018 | 05:30 AM
CMax03's Avatar
Good luck but you didn't bleed it enough..It may need you to get another person to help but make sure you bench bleed the master first!
maxcima
Apr 10, 2011 06:03 AM
modenaf1
Jul 27, 2008 02:54 PM
max88ima
Feb 15, 2005 08:48 PM
sbrett
Sep 26, 2004 12:52 AM
DMaximus
Dec 5, 2002 04:38 PM
