Jacking points
Old Feb 24, 2019 | 08:27 AM
candt's Avatar
Jacking points
Are the only jacking points on this car the four corners by the wheels between those two little notches? If so, is there some sort of an adapter you can get to use a floor jack in these areas instead of the scissor jack that comes with the car? Is there a central jacking point in the front of the car so I can jack up the entire front end at once instead of using the corners?
Old Feb 25, 2019 | 08:36 AM
gizzsdad's Avatar
Amazon Amazon
Old Feb 25, 2019 | 10:50 AM
Turbobink's Avatar
...page 28:
https://my4dsc-ic1urvd0hbui0649mdwc....NFORMATION.pdf
Old Feb 25, 2019 | 11:10 AM
MadMax07SL's Avatar
Nice find Gizzsdad!
Old Feb 25, 2019 | 12:55 PM
candt's Avatar
Thanks to both of you guys, that is just what I was looking for. Lots of good info in that book too. Where did you find it, and what is it?
Old Feb 25, 2019 | 03:20 PM
CerOf's Avatar
Just use a block of wood.
Old Feb 26, 2019 | 04:54 AM
Turbobink's Avatar
If this is the route taken (which is a reasonable one) be certain to cut a slit in the block of an adequate width. Otherwise you'll bend/crush your seam flange.
Old Feb 26, 2019 | 06:01 AM
Amerinamese's Avatar
That jack point in the front is what I prefer to use for oil changes on my other vehicles, but on my Max, the plastic shroud got in the way. My jack kept slipping off. I ended up jacking each side up at the side jack points and using jack stands instead. Has anyone else had trouble with the front jack point or is it just user error on my part?
Old Feb 26, 2019 | 09:44 AM
ellessone's Avatar
So if you are using those areas as the lift point for the jack, are you just putting the jack stand directly “behind” it on that same rail? Need to do oil change and debating on this or just building 2x12 ramps.
Old Feb 26, 2019 | 12:58 PM
I put the jack stands under the subframe near where the lower control arm bolts to the frame.
JeEvE
Garage and Workshop
Jun 12, 2008 01:44 PM
Bones45
Feb 15, 2006 08:13 AM
tian
Dec 29, 2004 05:51 AM
Cumalot
May 29, 2001 11:15 AM
Aug 25, 2000 03:51 PM
