Intelligent key seat position
Old Mar 4, 2019 | 12:26 PM
Steptide's Avatar
Hey guys, I cannot seem to figure this out and cannot find much on the internet or YouTube.
According to what I've read,, each key identification is supposed to remember seat and mirror positions . I don't have the seat memory on the driver door,, but I have the id thing turned on in the settings and the car recognizes both keys separately. However it does absolutely nothing to remember seat position between key 1 and key 2. I've done everything the Nissan owners channel says to do and still nothing. The seats stay in whatever position they were left in. Any advice is appreciated
Old Mar 4, 2019 | 03:06 PM
NisCal17's Avatar
I think it applies only to Platinum trim. All other models I believe will save radio presets with the key.
Old Mar 4, 2019 | 05:14 PM
Lemonhawk's Avatar
If there is no seat position selector on the door, then you don't have the seat memory option.
Old Mar 5, 2019 | 08:19 AM
Steptide's Avatar
OK Thanks. It's hard to tell,, the car is telling me it's recognizing the key, and the book doesnt specify which trim level does what etc. I'm not quite sure what the point of identifying each key is
Old Mar 5, 2019 | 08:32 AM
drakutis's Avatar
It's only on the platinum for the memory seats.
Old Mar 6, 2019 | 07:22 AM
Richard66's Avatar
The point is two different drivers will have different seat positions. Each driver will use their own key, and if the system works correctly the seats and mirrors will automatically adjust to the key's set positions when the car is started.
Old Mar 6, 2019 | 07:33 AM
Steptide's Avatar
Right I understand that. But if the sv trim doesn't have that (which is the trim I have ) I don't see the point of the car recognizing each indidual keys.
Old Mar 6, 2019 | 07:55 AM
Richard66's Avatar
OK exactly how is the car telling you that it is recognizing each key?
Old Mar 6, 2019 | 08:28 AM
Steptide's Avatar
The info screen in the gage cluster recognizes each key and says key 1 or key 2 when I start the car.
Old Mar 6, 2019 | 09:29 AM
Richard66's Avatar
Nice feature, wish I had that with my 7th gen. Could be that all trim levels with the 8th gen has that feature and only the premium model continues with that feature by adjusting seat/mirror positions. The only reason I could think of why your cluster is displaying that info is to tell you that your key is recognized and fully functional. Question - what does the display say when you start the car and you have both key fobs on you?
Old Mar 6, 2019 | 11:26 AM
Zatrekaz's Avatar
My SR does the same thing... they software on the SR and the Platinum is probably the same is all. It still recognizes the keys, but doesn't have the output of memory seats is all.
Old Mar 7, 2019 | 03:29 PM
grhmw's Avatar
I have a Platinum, I absolutely hate the key link feature. I often sit in my car during my lunchtime and adjust the seat. It seems like eveytime I get in the car I have to press the memory 1 button on the door. I just wish I could just unlock the car and have it go to my settings for memory button 1 regardless of where the keylink was last at. I do have the Keylink feature turned off and still have the issue.
Old Mar 7, 2019 | 04:06 PM
Richard66's Avatar
Very common problem effecting a lot of folks even in the 7th gen model. Just take it into the dealership and have them replace the control module for this feature.
Old Mar 7, 2019 | 07:09 PM
grhmw's Avatar
They will just tell me it works as designed just like they tell me they can’t find anything wrong with the power steering fluid that keeps going low, having to add power steering fluid it. I have topped it off from the low mark 3 times and I only have 14k miles on it. I hate the car, Only reason I am still driving it is because I am a little upside down on it.
Old Mar 8, 2019 | 06:39 AM
robtroxel's Avatar
Have your repair guy add some dye to the power steering res. The resulting leak will show up with a black light. Then go to your dealer. No need to take a haircut on this car, over just a leak in the P/S.
Old Mar 8, 2019 | 07:47 AM
Richard66's Avatar
Come on …. the Auto seat positioner system fails in your car and the dealership says that's as designed. It failed and that's what it's supposed to do. The PS system has a leak and they can't find it. Time for you to get a new service department. Both of those problems are easily fixable.
Old Mar 8, 2019 | 05:10 PM
Lemonhawk's Avatar
I think because you enabled Nissan Connect that it displays which key is in the car. I don't think it actually triggers anything on my
SR
dconn
Oct 23, 2022 02:07 PM
scutmud
Jun 30, 2016 05:16 AM
deesmax
Jul 27, 2015 07:46 PM
atlanta10
18
Sep 26, 2012 06:06 AM
jcalabria
34
Dec 20, 2003 12:58 PM
