No throttle response in gear
Replaced motor in a 1995 nissan maxima . Trans worked fine before motor went . The throttle response sucks I have to rev it up a few times for it to start being able to actually rev up thats with it in park or nuteral. In gear there is little to no throttle response I can be natted to the floor amd nothing any pointers are welcomed Im trying to get this vehicle on the road again since the gas miliage on my truck is pretty bad .
What’s the situation with the throttle linkage at the throttle body? With the enigine replacement did it get installed and adjusted correctly?
Check, adjust and replace if necessary the throttle position sensor.
I didnt mess with the sensor but maybe it could be bad I dont remmeber if we used the throttle body from the junk yard motor or if we swapped the one from the old motor so Ill look into the sensor . the throttle cable is hooked up just fine
95turbo gxe
Oct 18, 2007 11:46 PM
