Driver door lock and power windows don't work
On my 1995 Maxima SE all of a sudden the switch on my drivers side front door for the door locks stopped working. In addition all power windows switches do not work. My OEM alarm transmitter will lock and open all doors except the drivers side door. I have to open the driver side front door manually. I am going to check for fuses but this is pretty confusing. Was working fine yesterday. Any help or suggestions would be appreciated.
Open up the trim panel on the Driver's door and make sure the control button unit is still plugged in to the wiring harness. Make sure there isn't a short in the wiring harness in the door and especially in the door jam area where it passes from the door to the body. Maybe try opening and closing the door as you hold the buttons.
We've entered the Twilight Zone when all the quirky problems attack at the same time. LOL
I jiggled the door harness and everything worked again. The wrapping around the harness is brittle. Have to to check for a stripped or broken wire. After 25 years of exposure ans opening and closing probably starting to wear out.
I'm sure you'll repair the wiring harness. My advise is to not repair it in the door jam area, but rather cut out in the door and after it goes back into the body so the connections (solder and heavy duty heat shrink tubing) aren't where the constant bending occurs.
Best of luck! Good detective work.
Well since my post in April, the switch finally gave out what looks like for good. It happened with the window half way down and I can't get the window up. Tried jiggling the wire in the door space and it did not work. Window switches on all the other doors won't work either. My factory fob still lock and unlocks all doors except the driver side. Should I look to get an entire new driver side switch assembly or try diagnosing the wires? Is there any way to roll up the driver's side window until I get this fixed? Any help is appreciated.
I doubt HIGHLY there is anything wrong with the switch.
tripdaddy95
Jul 28, 2013 04:26 PM
venompwr2
Jan 3, 2003 08:49 PM
