A/C doesn’t blow cold air - used 2007 g35x
Car has been great otherwise feel welcomed in the Infiniti family but now that weather is warming up i just now noticed that the AC doesn’t work the way it’s supposed to. Climate set to 60 degrees with AC toggled on only gives the same temperature air.
Heat works. After 20 minutes air is still same temperature when set at 60. Just recently replaced a relay plug for the fan blower and that was an easy fix but now I found this out and don’t know what to do about it.
Anyone happen to know what the cause of this is? Any help is appreciated.
Last edited by DanNY; Jun 12, 2019 at 11:21 AM. Reason: yeah don't put links to other $h1t in your posts
Car has been great otherwise feel welcomed in the Infiniti family but now that weather is warming up i just now noticed that the AC doesn’t work the way it’s supposed to. Climate set to 60 degrees with AC toggled on only gives the same temperature air. Heat works. After 20 minutes air is still same temperature when set at 60. Just recently replaced a relay plug for the fan blower and that was an easy fix but now I found this out and don’t know what to do about it.
Is it cooling the car, I assume the compressor clutch is cycling...
ffcbairn
Jan 15, 2012 02:08 PM
