Cold startup smoke (bad valve seal)
Old Jul 4, 2019 | 07:49 PM
bebekhijau's Avatar
Have anyone have smoking issue at startup ( around 15 seconds ) after the engine turned off after serveral hours ? This is not exhaust condensation because will smoke also in hot weather. Also no coolant level decrease, no smoke smell from coolant reservoir (common head gasket issue).
From browsing @ google, it narrows down to bad valve seal.
I experiment installing Oil Catch Tank and the smoke issue gone. But the catch tank filled with oil at excessive level around 10 ml after driving 1 hours / 10 miles.
Later i will try to add slick 50 high milage oil treatment although mine just only 50k miles to see whether it will solve the issue if i remove the Oil catch tank.
Old Jul 5, 2019 | 05:07 PM
Bificus99's Avatar
No go on the slick 50. I would recommend BG 44K and loosen up rings instead.
Stormzusmc
29
Apr 12, 2010 03:05 PM
trialt
May 22, 2007 10:58 AM
99 Supercab
Jun 6, 2004 07:13 AM
krue92
21
Nov 4, 2003 06:07 AM
plurco
Apr 20, 2003 08:51 PM
