Fuel pump question
Old Jul 2, 2020 | 08:57 PM
Unrulynoodles's Avatar
Fuel pump question
Ok. This is a race car. So I had to put in a new fuel pump, and it seems like I am having a ground issue. My question is, will it be ok to just hook the pump to a switch and just leave it running while the car is running? Or do you have another suggestion?
Old Jul 2, 2020 | 11:51 PM
JvG's Avatar
JvG
I would use a relay which powers the fuel pump only while the engine is supposed up be on.
Fuel pump on load side, engine on trigger side.
Old Jul 3, 2020 | 03:33 AM
Would it be a relay I would need to buy? Or use an existing relay? I am not wonderful at wiring issues, but I am learning.. lol
Old Jul 3, 2020 | 12:51 PM
JvG's Avatar
JvG
you could use the one from the air conditioner, power windows, etc. Or from any circuit which you are no longer using.
just research how relays work. Then a wiring chart for our car which will show which teminal does what.
I'm thinking that a switch could be accidentally lent on. A leaking injector would flood the engine.
Did you already rip out most of the original wiring?
if not, the existing wiring already activates the pump only if the car is starting or running.
Sam Maxima
24
Sep 10, 2025 06:14 PM
YellowOne
Apr 15, 2007 05:04 PM
waveridr85
Jul 2, 2004 10:06 AM
KRMaxima21
Feb 19, 2004 03:58 PM
robocop199
Jan 25, 2003 06:38 PM
