What is proper MAF reading
Old Jul 8, 2020 | 12:16 AM
Veewee's Avatar
Can anyone share your MAF reading?
Mine VQ30 is around 5 gram/s 1.6 volts at 850rpm idle with AC off
According to FSM it is still in spec, but don't know why both bank LT and ST fuel trim always negative.
Thank you
Old Jul 8, 2020 | 05:39 AM
95naSTA's Avatar
How negative and how old are your front 02 sensors?
Old Jul 17, 2020 | 11:37 PM
Veewee's Avatar
​​​​​​Thanks for the reply.
Both bank are -11 on long term and around -5 on short term during idle, if acceleration long term will move closer to 0.
I don't know how old the oxygen sensor are, but the car have 187k miles on the clock.
After some live data reading I think my MAF is working fine.
But my idle speed is messed up, after warm up idle speed is around 850rpm and ignition timing at 5°(yeah 5° not 15°)
Already tried idle relearn but not successful, checked everything, no vacuum leak, the car is running fine just not perfect because the fuel trim and higher idle than official spec.
Is it normal that my Closed Throttle Switch always Off???
Old Jul 18, 2020 | 02:07 PM
Child_uv_KoRn's Avatar
Bad *** Newb
That would be why it's pulling fuel. Timing is too low, so it's nowhere close to burning fully. You're gonna have to figure that out. What's the timing do after idle and under load?
850 is a good idle speed, anyway. That gives you higher oil pressure.
Old Jul 19, 2020 | 10:25 AM
Veewee's Avatar
Thanks for your reply.
Timing after idle and under load I think is normal, between 10° to 40°. I guess my job now is to bring the idle timing back to 15° first. From what I read the ECU will lower the idle timing when the IACV can't bring down the idle speed, but I'm not sure is it true or not...
850 idle also smoother than 700.
Old Jul 20, 2020 | 02:29 AM
Veewee's Avatar
Well, just found out my fuel pressure regulator has small amount of fuel leaking from vacuum port, also the same thing happen on fuel pressure damper but it's worst than the FPR....
Old Jul 20, 2020 | 08:52 AM
95naSTA's Avatar
That would make sense for the rich trims. Let us know if it fixes it.
Old Jul 20, 2020 | 12:35 PM
Bad *** Newb
Interesting.... What's with the timing, though...
Black_Magic
May 20, 2010 09:15 AM
ornery1
Jul 31, 2006 06:43 PM
JdoubleOe703
May 15, 2006 11:05 AM
Grey00lustre
56
Sep 9, 2005 07:53 PM
