Starting problem. Often won't crank, shifting to Neutral usually works.
Old Dec 22, 2020 | 06:33 PM
90sWheels's Avatar
Like I said, starting is an issue with my new wheels. If shifting to Neutral gets the starter to crank does this mean I have a bad transmission sensor? I read a thread about how someone's negative battery cable was corroded and that was the issue. Another person had corrosion between the engine and the transmission. Other people mention the anti-theft system, the ignition switch, or the slop between the key and the ignition switch. The question is: what's my problem?
At first I thought it might be key slop, but then why would shifting to neutral help? I'm thinking of pulling fuse #61 under the hood to disable the anti-theft system. How big a deal is it to install a new transmission sensor?
Old Dec 22, 2020 | 06:52 PM
saig's Avatar
Sometimes, my car does this too. All I have to do is push the gear selector stick back to P direction then turn key again. Like almost all the time, it worked for me.
The switch is mounted on the transmission, referred in FSM as Inhibitor switch. It is located under the battery, You can access it after removing the splash guard underneath.
There's a video on YT if you want to get to it:
Hope you can resolve your issue.
Old Dec 23, 2020 | 06:14 PM
90sWheels's Avatar
There's a video on YT if you want to get to it: https://www.youtube.com/watch?v=VcX6...nnel=CarsNToys
Thanks, that looks promising! (Wait does the sticky say not to thanks post? You guys need to update the forum to include thumbs up reactions, etc).
Although, tbh I don't quite understand what gets out of alignment. Maybe it's time to pick up a Haynes manual (if that's the recommended book).
I drove today with 3 starts and no problems... mysterious.
Spartuss
Aug 29, 2011 10:43 AM
jobell
Aug 21, 2009 01:24 PM
iDuty
Sep 29, 2008 05:46 AM
overbo0st2k4
Jun 22, 2007 12:43 PM
chillin014
21
Oct 18, 2005 07:31 PM
